1Back to top Go down   Bodger's injectors guard Empty Bodger's injectors guard Fri Apr 05, 2013 6:40 pm
Comberjohn
Comberjohn
Just fitted this to my K. Made it from a piece of aluminium grill left over from the stone guard I made for the radiator.
Folded the edges to make it rigid and fixed it to the bolts holding the injector rail with a couple of brackets.
Cost pennys to make.
[img]Bodger's injectors guard 20130410[/img]
Life is not a rehearsal.
2010 VFR 1200F DCT
2010 R1200GS(gone)
1986 K100 Silver(gone)
2012 K1600GT(gone)
1984 K100 Red(gone)
2Back to top Go down   Bodger's injectors guard Empty Re: Bodger's injectors guard Fri Apr 05, 2013 8:12 pm
looks good cj
dang thought for a second someone had stole my bike ...giggle ( looks extreemly similar ) onya mate !
3Back to top Go down   Bodger's injectors guard Empty Re: Bodger's injectors guard Fri Apr 05, 2013 9:43 pm
An elegantly simple solution CJ! Those engine covers gleam too. I must say I like the way you're going with this whole naked machine, little individual toutches everywhere but without compromising the whole K bike origin.
Bodger's injectors guard Ir-log1188....May contain nuts!Bodger's injectors guard Ir-log11
K75RTP - 1994
4Back to top Go down   Bodger's injectors guard Empty Re: Bodger's injectors guard Sat Apr 06, 2013 5:11 am
JGT
JGT
That looks useful. I need something to protect the front of my radiator. Where did you source the grill from? John
5Back to top Go down   Bodger's injectors guard Empty Re: Bodger's injectors guard Sat Apr 06, 2013 5:29 am
Comberjohn
Comberjohn
Bought a sheet of it from B&Q (UK hardware store) for about £8. They had a range of different types.
Cut to shape with small cutters and drilled small holes in the flange top and bottom of the radiator. Fixed with small Allen bolts and lock nuts.
Split some rubber fuel line and run it along the top and bottom of the radiator. The edges of the sheeting are sharp.
Left it shiny so far but may paint it with good old Hammerite satin black same as the injector cover.
2010 VFR 1200F DCT
2010 R1200GS(gone)
2012 K1600GT(gone)
1984 K100 Red(gone)
6Back to top Go down   Bodger's injectors guard Empty Re: Bodger's injectors guard Sat Apr 06, 2013 1:20 pm
JGT
JGT
Spot on. Will be paying B&Q a visit. John
7Back to top Go down   Bodger's injectors guard Empty Re: Bodger's injectors guard Mon Apr 08, 2013 4:17 pm
Tenox
Tenox
I was wondering is there some potential risk of malfunction or something if injectors are not covered? Mine are not, so I'm just thinking should I do my own shield too? Question
BMW K100RT Scrambler (86)
8Back to top Go down   Bodger's injectors guard Empty Re: Bodger's injectors guard Mon Apr 08, 2013 4:33 pm
Comberjohn
Comberjohn
No mechanical reason to cover them, although I suppose it would keep curious fingers from fiddling.
Motorworks can supply a plain, black plastic cover similar to the original, complete with the mounting bolts for about £20.
2010 VFR 1200F DCT
2010 R1200GS(gone)
2012 K1600GT(gone)
1984 K100 Red(gone)
9Back to top Go down   Bodger's injectors guard Empty Re: Bodger's injectors guard Mon Apr 08, 2013 6:21 pm
MikeP
MikeP
Indeed they do:
Bodger's injectors guard BMW%20K75S%28313%29-L
It was originally an after-market bit of "bling" (produced by Wunderlich I think), now reproduced by Motorworks. It tidies-up the look on bikes that don't have a fairing panel covering the injectors and furl rail.
10Back to top Go down   Bodger's injectors guard Empty Re: Bodger's injectors guard Tue Apr 09, 2013 2:14 am
Tenox
Tenox
I actually have all the materials for shield making, but I think I will do it not sooner than winter 13-14. Concentrating on driving now. Very Happy
Thanks again.
