1 Water + Oil Sensor wiring Fri Apr 19, 2013 3:41 pm
twincarb
Ok needing some ideas here.... I have got both the water and oil pressure sensor on my LT, the Oil sensor wire is still attached to the sensor.... But the water temp sensor has managed to work it's way back into the oil/water pump! what options or ideas are there for feeding the water one back down and out of the hole....
I have considered replacing both wires as it would mean I can use the oil pump wire as a tracer wire when pulling the new through... has anyone done similar? I could try adding some string to the oil wire and pulling that all the way back through but would like to know if anyone has had success any other way before!
BMW K100LT 1988
Yamaha Thundercat
