1 Rev Counter Thu Aug 23, 2012 6:50 pm
twincarb
Evening all...
Just spent the day playing with the old K the engine is now running bit hesitant when the throttle is twisted mind but I will look at that later.
The Rev counter wasn't working so went into logic mode checked the wiring out to the cluster all good.... Whipped the cluster apart and not looking good inside...
The Rev Counter side must have got wet inside as there was corrosion galore I have cleaned everything up and had to replace a broken leg that go's onto the meter itself. As can be seen below.
I have put it all back together and tested the unit and the Rev counter itself works. The gear selector indicator doesn't mind hmmmpphhh.
I have had a look at moto-bins and they stock 2 parts one is Rev Counter for £100 and the other is £66.50 gear display and cct board. Need to phone them tomorrow unless anyone knows if the £100 part includes the gear display?
BMW K100LT 1988
Yamaha Thundercat
