1 A new approach to faulty earths Fri Mar 29, 2013 2:50 am
ibjman
I have not seen this tip here....
I once learned a neat trick that the Cummins engine company now uses as a diagnostic aid. It is routinely factory installed on many of their newer electronically controlled diesel engines.
Cummins installs a "telltale" fuse between the frame and the engine block.
This is a 1/2 amp very light duty fuse. Any time a technician could suspect unknown electrical gremlins.......he need only inspect the fuse. If he finds that fuse blown, he knows that he has a faulty ground somewhere in the wiring.
I thought.........how cool is that??????
