1Back to top Go down   LCD clocks Empty LCD clocks Mon Mar 25, 2013 2:02 am
Themason
Themason
I have two '84 vintage K100RS. On the older of the two, the digital read out of the clock is fine, but it is unlit at night. On the more recent of the two, the digital clock lights up fine, but the the LCD has a couple of dead cells. I have a third clock in a spare instrument cluster with a non working speedo that is a known good clock.
There would seem to be the opportunity to make two good clocks out of the available parts. Number one, how does one remove and replace the digital clock?
Number two, how are they lit and would it be possible to remove the light from the clock with the defective read out and put it in the clock with a good read out but no light? Thanks in advance for any help.
1986 R-80G/S w/1000 cc engine
2Back to top Go down   LCD clocks Empty Re: LCD clocks Mon Mar 25, 2013 2:16 am
Just did mine. Easy. Clocks a back lit. Replace the globe
Remove the whole unit from the housing.
Remove the three screws from each of the face plates. This will make them loose. Depending how brave you are or how dextrous that may be all you need.
The clock has a black mounting/locking ring that is square. It has a lip that sits under each of the speedo and tachometer face plates.
Remove the ring, plastic and easy to break and the clock just slips out.
Reverse to fit the new clock.
Replace any blown globes while there.
Just plug in the wires, turn on the key and list and see which need replacing.
3Back to top Go down   LCD clocks Empty Re: LCD clocks Mon Mar 25, 2013 3:01 am
twincarb
twincarb
+1 To the clocks being back lit..... Took me about 18 months of ownership to find that one out and replace the bulb!
Yamaha Thundercat
LCD clocks 169042LCD clocks 169034
4Back to top Go down   LCD clocks Empty Re: LCD clocks Mon Mar 25, 2013 11:46 am
Themason
Themason
Rossco, I had that square black surround off the clock. Which way do you pull the clock after removing that surround? Don't assume this is obvious to me, it is not. I don't want to start yanking on things and do damage. So there are replaceable lights behind the clock? This is good news.
5Back to top Go down   LCD clocks Empty Re: LCD clocks Mon Mar 25, 2013 4:55 pm
dmanley
dmanley
Go to the forums download section and get a copy of the Clymer manual. It gives a step by step procedure for working on the instrument cluster. Really easy once you know which connectors and screws to loosen. I just did mine.
Daryl
1985 K100RT
6Back to top Go down   LCD clocks Empty Re: LCD clocks Mon Mar 25, 2013 10:21 pm
If you remove the LCD face before replacing it clean the area with a soft white pencil eraser it does a good job and it fairly gentle on the surface and then try to avoid touching the surface as even finger prints can start corosion going.
If you do need new clocks they are available from a guy on US Ebay.
7Back to top Go down   LCD clocks Empty Re: LCD clocks Tue Mar 26, 2013 4:07 am
andyb
andyb
Hi Mason. If you have removed the black plastic surround, then at the base of the clock, left and right, top and bottom are small plastic tangs holding the clock in place. Gently remove from one side and then the other and gently remove upwards - there are two female connectors on the back of the clock that those long male pins go into, which can bend easily. Then its easy to access the bulb underneath for replacement. New clock just pushes down on the pins and click into place with the 4 plastic tangs ( I guesss they are called tangs! ) and replace the black surround - done!
AndyB
'03 K1200GT,
'88 K100 RT
Chassis number: 0097248 ; Vehicle code: 0504; Series: K589
Model: K100RT 84 (0504 (0505) Body Type: K100RT 84 (0504)
Catalog Model: ECE; Engine: (0504); Production: 1988/9
LCD clocks 13763011
8Back to top Go down   LCD clocks Empty Re: LCD clocks Tue Mar 26, 2013 4:28 am
LCD clocks Clock110
LCD clocks Clock210
LCD clocks Clock410
Hope this helps
rossco
9Back to top Go down   LCD clocks Empty Re: LCD clocks Tue Mar 26, 2013 8:26 pm
Themason
Themason
Thank all of you very very much. All these years I have been told that once the light in the clock goes out you live with it or replace the clock. This will not be difficult to remedy. Thanks again.
