1 Sprag clutch cleaning (on center stand or do I have to ride?) Tue Mar 12, 2013 1:13 am
excorcist
Basically I need the sprag clutch to be cleaned and i Just wanted to make sure it would get the oil (with detergent) circulating and cleaning it with the bike on the center stand and if it should be in neutral or in gear?
I have read that you should bump start it and then ride it for about 500 miles Im just wondering if running it in neutral will have the same effect, on the center stand, or should I put it in gear? or is the only way to ride it....
