1Back to top Go down   [solved]Electric Windscreen Empty Electric Windscreen Sat Oct 06, 2012 6:06 am
gmcq
gmcq
The microswitch on my electric windscreen has broken. BMW do not do this part but will gladly sell the motor assembly for £190 + VAT (extra 20%). Has anyone ever sourced this switch? What is the correct terminology for the switch i.e. is it a single pole double throw, dual circuit type. The ones I have seen online only have one push button, this switch has two. As always thanks
Gerard
1996 K1100LTIC 0235790
2Back to top Go down   [solved]Electric Windscreen Empty Re: [solved]Electric Windscreen Sat Oct 06, 2012 7:27 am
If it makes the screen go up and down then it must be a double pole double throw to operate both actions?? wouldn't that sound right? I know I'll go look in the shed and read the wiring diagram, um may take awhile as daughter has right of way when I get off here.
3Back to top Go down   [solved]Electric Windscreen Empty Re: [solved]Electric Windscreen Sat Oct 06, 2012 8:22 am
i havent seen the micro switch assembly yet ....but could possibly be 2 small factor microswitches bolted together ?
anybody got a good clear pic ?
4Back to top Go down   [solved]Electric Windscreen Empty Re: [solved]Electric Windscreen Sat Oct 06, 2012 8:32 am
gmcq wrote:The microswitch on my electric windscreen has broken. BMW do not do this part but will gladly sell the motor assembly for £190 + VAT (extra 20%). Has anyone ever sourced this switch? What is the correct terminology for the switch i.e. is it a single pole double throw, dual circuit type. The ones I have seen online only have one push button, this switch has two. As always thanks
Gerard
Gerard. You might remember me chatting to you about windscreen electrics outside cafe Chimes in Hillsborough. I have an electric window motor here from a classic Range Rover (same as landrover discovery too) with what appears to be an indetical motor and micro switches as the K screen one. I believe it is just the factory settings on the cams to activate the micro switch that differs.
That said I have to do a bit more poking at it to compare both which involves getting my screen off. (That needs to be done anyway) So I'm away now for the next 36 hours but I'll have a close look when I get back and if they are the same I'll pop one of the micro switches in the post to you.
[solved]Electric Windscreen Ir-log1188....May contain nuts![solved]Electric Windscreen Ir-log11
K75RTP - 1994
5Back to top Go down   [solved]Electric Windscreen Empty Re: [solved]Electric Windscreen Sat Oct 06, 2012 8:38 am
gmcq
gmcq
88 your a gent! Thanks
6Back to top Go down   [solved]Electric Windscreen Empty Re: [solved]Electric Windscreen Sat Oct 06, 2012 11:14 am
I recall Inge saying that some of the BMW cars have the same motors in the sunroofs so there may be some micro switches there as well
7Back to top Go down   [solved]Electric Windscreen Empty Re: [solved]Electric Windscreen Sat Oct 06, 2012 1:40 pm
charlie99 wrote:i havent seen the micro switch assembly yet ....but could possibly be 2 small factor microswitches bolted together ?
the assembly consists of two microswitches riveted together. The picture below does not show the two switches but they are stacked.
[solved]Electric Windscreen 013%2520%25282%2529
If you feel inspired, it might be possible to drill out the rivets, replace the one failing switch and reassemble. I think this operation would require dexterity and the means to remove the motor assembly for accessibility. The replacement micoswitch would be "SPST NO momentary contact".
8Back to top Go down   [solved]Electric Windscreen Empty Re: [solved]Electric Windscreen Sat Oct 06, 2012 2:05 pm
The switch is delivered from a Swiss company called Polycontact,
haven`t found them as single parts from any other companies.
Some have used a model called HPS 32 from Petercemswitch, which is a direct fit.
As Rick says it`s a sunroof motor and mechanism used on the E32 and E34 sedans.
These motor/mechanism shows up at Ebay now and then.
9Back to top Go down   [solved]Electric Windscreen Empty Re: [solved]Electric Windscreen Sat Oct 06, 2012 3:25 pm
gmcq
gmcq
Thanks guys
10Back to top Go down   [solved]Electric Windscreen Empty Re: [solved]Electric Windscreen Sat Oct 06, 2012 3:55 pm
ah !....thanks robmack
i had a feeling that that would be the case .
looking at the dimensions and relative sizes , they look pretty standard to me .
"omron" carry a huge range of microswitches . with one suitable im sure they list all sorts of actuator length , position and activation presure . having said that , most of them at spdt and looking at the application those rivets could be drilled out easy and replaced with 2.5mm screws that we use in my industry ...probably 15 mm would suffice with some nylock nuts (not really neccessary though )
even the "generic " type switches would be suitable in this application i recon .
something i puled out of one of my work spares boxes , lever removed for clarity and application
[solved]Electric Windscreen 2012-111
in this size pretty much all the hole centres and depths of actuator are fairly similar
get youself down to a "radionics " (out here called "rs spares " store) and you should have one for under 3 bucks
hope this helps
this panasonic looks a suitable candidate, catalogue no 699 5317 but have a look in their huge parts book before ordereing dont forget most of the levers are remoovable if looking at something else of similar size
<TABLE class=listViewFlags>
<TR>
<td width="100%">[solved]Electric Windscreen R6995305-01 </TD>
<td class=listFlags></TD></TR></TABLE>699-5317
Panasonic
AH1660A
Plunger
SPDT
2 A @ 30 V dc, 3 A @ 125 V ac
Solder
€1.55Each
Real
11Back to top Go down   [solved]Electric Windscreen Empty Re: [solved]Electric Windscreen Sat Oct 06, 2012 4:02 pm
This is the dimensioned drawing for the replacement switch identified by Inge (HPS32):
[solved]Electric Windscreen HPS32%2520Microswitch%2520Dimensions
Dimensions are in millimeters.
Critical dimensions would be (1) the mounting hole spacing 9.5mm (2) the distance between the mounting hole and plunger 8.9mm (3) thickness of the switch 6.35mm.
Isn't the big electronics supplier in the UK "Radiospares" or "RS Electronics"?
12Back to top Go down   [solved]Electric Windscreen Empty Re: [solved]Electric Windscreen Sat Oct 06, 2012 4:22 pm
The c/c distance between the holes on the genuine switches is 9 mm, by using 2 mm screws...it`s close as....
Haven`t written down the hole dimension at the plate, it seems like...no mods needed.
[solved]Electric Windscreen Altern10
13Back to top Go down   [solved]Electric Windscreen Empty Re: [solved]Electric Windscreen Sat Oct 06, 2012 4:26 pm
robmack wrote:Dimensions are in millimeters.
radionics im reliably informed rob ...same website world over , just different local names
and yes 2.0mm screws oops ..
14Back to top Go down   [solved]Electric Windscreen Empty Re: [solved]Electric Windscreen Mon Dec 24, 2012 4:12 am
gmcq
gmcq
Further to the above, i am getting a couple of micro switches today. Anyone have a wiring diagram to cover from relays to motor & micro switches?
GMcQ
15Back to top Go down   [solved]Electric Windscreen Empty Re: [solved]Electric Windscreen Mon Dec 24, 2012 6:55 am
A wiring diagram you find here.
16Back to top Go down   [solved]Electric Windscreen Empty Re: [solved]Electric Windscreen Mon Dec 24, 2012 8:46 am
gmcq
gmcq
Thanks Inge
17Back to top Go down   [solved]Electric Windscreen Empty Re: [solved]Electric Windscreen Wed Dec 26, 2012 6:04 am
gmcq
gmcq
Got two microswitches from Maplins as close to the above measurements as possible. Two differences, the pins are in a different order and the plunger did not meet the cams. I held the switches in position, marked the mounting plate and drilled a further two holes. Switches mounted, wires soldered and it works! I did have the screen working via a switch mounted on the bars and by passing the relays, motor powered direct from the battery but much better/ safer having the original setup working. Thanks guys Very Happy
18Back to top Go down   [solved]Electric Windscreen Empty Re: [solved]Electric Windscreen Wed Dec 26, 2012 6:11 am
Good result G. Mental notes made for the future!
K75RTP - 1994
19Back to top Go down   [solved]Electric Windscreen Empty Re: [solved]Electric Windscreen Wed Mar 13, 2013 7:08 pm
George R
Hi Gerald - I also now have a problem with the microswitch for the screen, but in my case the wires have broken away from the switch, and even after cleaning, cannot get the cables to solder on to the posts. So I have had a look at the Maplin website for their microswitches, and are totally confused with the selection (not difficult!!) Anyway can you tell me the part numbers for the switches you used and how you wired up the cables. I realise that C is common and are joined by the brown cable but did you use the NO or NC pins for the yellow wires ?
Thanks in advance
George
20Back to top Go down   [solved]Electric Windscreen Empty Re: [solved]Electric Windscreen Thu Mar 14, 2013 12:02 am
George R wrote:... did you use the NO or NC pins for the yellow wires ?
Use the Normally open contacts.
