[img]
[/img]
Firstly, yes, nick off Rossco. Hadn't got around to getting a couple of mirrors yet but with the sun out and a heady 10C I couldn't resist it. Still not sure which type of mirror yet as a bar change is a possibility. Slightly more forward position with standard type K100 bars. Not original at £130 though!
Thought of reversing the headlight brackets, Charlie. But after careful consideration it wouldn't make any difference. The light would still be at the same height. The clocks have to come down! Noticed on a recent photo of one of those 'Pilchard' fairings, the clocks are re positioned lower down in the fairing bracket.
Blakey, I know what you mean about should I keep the fairing on or not. I struggled with it too. It felt like I was doing something very bad.
But its like I have a different bike. I know its probably partly imagination but it feels like it really lifts, brakes better and handles much better. Its much easier to use at slow speeds in traffic too. No wobbly top heavy feel.
On the twisties it just encourages you to really get into the corners and power out again.
In a word its FUN!
Starting to worry about my licence as it does encourage hooligan behaviour. Not very BMW like.
Will. I removed the risers but the clocks are still original. It was only the dashpad that had to be raised on mine. The clocks bracket can't be reversed but could be lowered by about an inch by re-drilling the mounting holes. Not sure if its worth it for an inch.
I would like to drop the headlight brackets down a bit if I can lower the clocks. The only way I can see is to cut and drill two lengths of steel or aluminium flat bar that can be fixed to the two threaded holes on both the top and bottom yokes.
The top yoke ones are used to hold the clocks bracket but the bottom ones are redundant. I used them to mount the horns.
I think I could then fix the clocks at any point on these two bars by simply drilling a couple of holes at the correct height. Don't think it would be too noticeable behind the headlight.
The pinstripes came in a roll from eBay for a couple of quid. Just took a little patience and a few bad words to fit. They do stick well once they are on, though.
