Go to page : Previous  1, 2
51Back to top Go down   Repositioning the clocks - Page 2 Empty Re: Repositioning the clocks Sun Mar 03, 2013 12:00 am
Comberjohn
Decided to keep the RT bars. Just waiting for the mirrors to arrive.
Note the cleaner looking back end with the luggage rack and pannier rails removed. Change of exhaust would be nice.
Repositioning the clocks - Page 2 20130310
The flyscreen seems to work well, although I must admit, a couple of times today I did miss the fairing with the temperature being on the low side. Hmm, maybe I need to find another RT for next winter.
But sure its Spring now, isn't it!
Repositioning the clocks - Page 2 20130311
52Back to top Go down   Repositioning the clocks - Page 2 Empty Re: Repositioning the clocks Sun Mar 03, 2013 12:15 am
Wow!
It looks like a "proper" motorcycle. I love it!
53Back to top Go down   Repositioning the clocks - Page 2 Empty Re: Repositioning the clocks Sun Mar 03, 2013 1:17 am
Excellent result. I agree with Blakey. I like the logo on the hub cap.
CJ, just ride it for five minutes to warm it up, get off and let it sit running for two minutes and get back on when the days a a bit cooler.
I notice sitting at the lights raises the temp a lot and the warm air that flows back can be very welcomed when the fairing is gone.
54Back to top Go down   Repositioning the clocks - Page 2 Empty Re: Repositioning the clocks Sun Mar 03, 2013 1:56 am
that little screen does the job fantasticly john...looks great
55Back to top Go down   Repositioning the clocks - Page 2 Empty Re: Repositioning the clocks Sun Mar 03, 2013 2:39 am
CJ a very tidy 84 there my man....if only there were quick disconnects for fairings for those cold/wet days but not a bad compromise the way it is....certainly for a country with good weather...heeheee
KKlompy Repositioning the clocks - Page 2 2854237993
Repositioning the clocks - Page 2 Au-log10
56Back to top Go down   Repositioning the clocks - Page 2 Empty Re: Repositioning the clocks Sun Mar 03, 2013 9:28 am
Love it CJ Repositioning the clocks - Page 2 723598 I really love the radiator Cowl on the naked C type bikes and s change of noise can would really crown it :king:
I'm definitely taking you up on the offer of a spin!
Repositioning the clocks - Page 2 Ir-log1188....May contain nuts!Repositioning the clocks - Page 2 Ir-log11
K75RTP - 1994
57Back to top Go down   Repositioning the clocks - Page 2 Empty Re: Repositioning the clocks Sun Mar 03, 2013 10:06 am
Ok. After my reply that I said I would post photos and I didnt and then said I wouldnt well now I am.
This is the K100/2 headlight and clock mount with a standard RT dash and bars compared to a RT clock mount with standard RT dash and K100 bars.
Ignore the bars as the dash mount is the same. Just typed that for a bit of clarity. Unless it just confuses things.
Compare the clocks to the dash on both and the top of the forks on both.
The /2 mount is a good few inches lower.
Repositioning the clocks - Page 2 Dsc04711
Repositioning the clocks - Page 2 Dsc04712
And now with the standard RT dash and mount.
Repositioning the clocks - Page 2 Dsc04713
Repositioning the clocks - Page 2 Dsc04714
58Back to top Go down   Repositioning the clocks - Page 2 Empty Re: Repositioning the clocks Sun Mar 03, 2013 12:44 pm
Bigsax
Bigsax
Comberjohn wrote:Decided to keep the RT bars. Just waiting for the mirrors to arrive.
Looking great Comberjohn!
Did you do anything about the height of the speedo? I have just swapped my handlebars from RS to RT and the new seating angle means that I am getting sun glare direct to my retina's. 36 degrees of sunshine here today. (the norm)
We could swap brackets?
Repositioning the clocks - Page 2 Brick110
I stole this image, let me know if you want it back.
59Back to top Go down   Repositioning the clocks - Page 2 Empty Re: Repositioning the clocks Sun Mar 03, 2013 12:58 pm
Comberjohn
Comberjohn
Was able to drop the clocks by about 23mm by re drilling the mounting bracket. Not sure if that would help your problem.
There seems to be two different types of mounting bracket. Mine is a simple angled bracket but one recently on eBay and according to the drawing on RealOEM, a different bracket can also be attached using a couple of small fittings.
Check which type you need before parting with any money or start cutting anything.
60Back to top Go down   Repositioning the clocks - Page 2 Empty Re: Repositioning the clocks Mon Mar 04, 2013 5:00 am
Bigsax
Bigsax
Comberjohn, I am loving the look of your bike! Where did you get the tank pads from?
61Back to top Go down   Repositioning the clocks - Page 2 Empty Re: Repositioning the clocks Mon Mar 04, 2013 7:06 am
Bigsax wrote: Where did you get the tank pads from?
Give up on those Bigsax.
Ainsjac was in a bid for some recently. Over $100 from memory. For 2 bits o plastic.
They are available I believe from Motorworks/ Bins at a very high price.
02 KNEE PADDING LEFT SW 1 16111455331 $84.38
02 KNEE PADDING RIGHT SW 1 16111455332 $84.38
62Back to top Go down   Repositioning the clocks - Page 2 Empty Re: Repositioning the clocks Mon Mar 04, 2013 7:16 am
Bigsax
Bigsax
Consider them forgotten!
63Back to top Go down   Repositioning the clocks - Page 2 Empty Re: Repositioning the clocks Mon Mar 04, 2013 7:56 am
Comberjohn
Comberjohn
Bigsax, the pads were on it when I bought it.
The good news is that they aren't original, expensive pads. They are made from a '3D carbon fibre' type material, cut to shape.
Widely available on eBay for a few pounds.
I had always fancied the original tank pads but wouldn't pay those prices either.
The ones I have now are very effective and are sticking well. Recommended.
64Back to top Go down   Repositioning the clocks - Page 2 Empty Re: Repositioning the clocks Mon Mar 04, 2013 8:36 am
You can make your own pads using cheap car mudflaps, just cut out your own shape.
65Back to top Go down   Repositioning the clocks - Page 2 Empty Re: Repositioning the clocks Mon Mar 04, 2013 8:39 am
Bigsax
Bigsax
ainsjac wrote:You can make your own pads using cheap car mudflaps, just cut out your own shape.
Actually I was thinking of going to Clark Rubber and see what they have, I have seen some very high density stick on foam sheeting that may do the job.
66Back to top Go down   Repositioning the clocks - Page 2 Empty Re: Repositioning the clocks Mon Mar 04, 2013 8:51 am
I did try that first, but the self stickers can't take too much heat and the tank does get hot. Have a look at my thread..a journey begins. You need to use silicon as a "glue".
