1Back to top Go down   Greetings From Richmond, Virginia Empty Greetings From Richmond, Virginia Wed Jan 16, 2013 9:49 pm
JaxBmw
JaxBmw
Hello from Richmond, VA, USA. I'm Jack and a long time Beemer rider. Started with an R75/5 in '73 and kept going from there. With a few other lesser brands thrown in for spice! Actually found this site in searching for a little help in freeing up my seat lock on my '87 K100RS. Not frozen, but the lock is stuck and can't get the seat open. Rather than take a hammer and torch to it, thought I'd look for a simpler solution to fixing it before I dreamt up my own solution. Anyway, the site looks great and there's some really fine information and stories here. Looks like fun. Thanks...........................
JaxBmw - 1987 K100RS, 2012 K1600GT, 2005 HD Electra Glide, 1989 Softail, 1978 Yamaha XS1100, 1973 Triumph Bonneville - Rickman Frame and a host of airheads in a different life.
http://www.sim-seats.com
G'day Jax and welcome to the Forum.
Have a look here; this may help.
JaxBmw
JaxBmw
blakey wrote:G'day Jax and welcome to the Forum.
Thanks! I checked that one out and it will be of great help, as soon as I figure how to get the seat opened up with the lock stuck!
4Back to top Go down   Greetings From Richmond, Virginia Empty Re: Greetings From Richmond, Virginia Wed Jan 16, 2013 10:53 pm
Ok, I'm going to state the obvious...you have sprayed some lubricant in the key hole, haven't you?
The lock is attached to the frame with two 8mm bolts from the rear and 2 Phillips head screws from the front.
Good luck.
5Back to top Go down   Greetings From Richmond, Virginia Empty Re: Greetings From Richmond, Virginia Wed Jan 16, 2013 11:18 pm
pavie
pavie
Welcome, you are going to enjoy the forum.
6Back to top Go down   Greetings From Richmond, Virginia Empty Re: Greetings From Richmond, Virginia Wed Jan 16, 2013 11:26 pm
Welcome to the forum Jax.
Sit on it.
Have someone push the button.
Unless you have a dextrous finger and can manage these things on your own.
Then stand up (maybe on the pegs) with the button still pressed.
Lift the seat.
Problem solved.
Nurse, send in the next patient.
rossco
7Back to top Go down   Greetings From Richmond, Virginia Empty Re: Greetings From Richmond, Virginia Wed Jan 16, 2013 11:40 pm
Greetings Jack welcome to our version of a funny farm.
Rossco was it you who found that your key fitted something like 3 other bikes. Not sure if our bikes are safe with you around Very Happy how do you know these things.
8Back to top Go down   Greetings From Richmond, Virginia Empty Re: Greetings From Richmond, Virginia Wed Jan 16, 2013 11:45 pm
Rick G wrote:Rossco was it you who found that your key fitted something like 3 other bikes. Not sure if our bikes are safe with you around Very Happy how do you know these things.
Not I. I would be looking closer to home for you Rick. cough charlie cough alby cough
9Back to top Go down   Greetings From Richmond, Virginia Empty Re: Greetings From Richmond, Virginia Thu Jan 17, 2013 12:51 am
brickrider
brickrider
Welcome Jack. I reckon if you can't get the help needed to sort out your seat lock problem here, it's impossible to ever fix!
After it's taken care of, stick around. The more the merrier!
10Back to top Go down   Greetings From Richmond, Virginia Empty Re: Greetings From Richmond, Virginia Thu Jan 17, 2013 5:33 am
Hang in there Jax, if all else fails ,these guys will have you chuckling in your seat , that should loosen something Very Happy Very Happy Very Happy
Greetings From Richmond, Virginia 10_x_110
11Back to top Go down   Greetings From Richmond, Virginia Empty Re: Greetings From Richmond, Virginia Fri Jan 18, 2013 5:31 pm
JaxBmw
JaxBmw
groverK wrote:Hang in there Jax, if all else fails ,these guys will have you chuckling in your seat , that should loosen something Very Happy Very Happy Very Happy
Yeah, thanks guys! A pretty lively group for sure. Headed into the garage now to work on this troublesome little lock. It's not that it's frozen or stuck. The button pushes in fine, the latch won't release. Sort of like a little gizmo in there that moves the latch failed! Go figure, the thing's only 26 years old and with all the junk that I keep under the seat that I constantly need to get at, it's a wonder it didn't break years ago. Time to go play locksmith!
12Back to top Go down   Greetings From Richmond, Virginia Empty Re: Greetings From Richmond, Virginia Fri Jan 18, 2013 10:49 pm
krambo
krambo
Welcome aboard Jax - if your problem cannot be solved by this forum's members I will be greatly surprised Wink
"Aut viam inveniam aut faciam." Greetings From Richmond, Virginia Uk-bmw12
http://www.its-personal.net
13Back to top Go down   Greetings From Richmond, Virginia Empty Re: Greetings From Richmond, Virginia Sat Jan 19, 2013 6:33 am
krambo wrote:........ if your problem cannot be solved by this forum's members I will be greatly surprised Wink
+1
Greetings From Richmond, Virginia 177912 Jax.
Greetings From Richmond, Virginia Ir-log1188....May contain nuts!Greetings From Richmond, Virginia Ir-log11
K75RTP - 1994
14Back to top Go down   Greetings From Richmond, Virginia Empty Re: Greetings From Richmond, Virginia Sat Jan 19, 2013 6:41 am
welcome jax ...have fun mate !
15Back to top Go down   Greetings From Richmond, Virginia Empty Re: Greetings From Richmond, Virginia Sat Jan 19, 2013 7:42 am
Welcome to the madhouse, Jax.
16Back to top Go down   Greetings From Richmond, Virginia Empty Re: Greetings From Richmond, Virginia Sat Jan 19, 2013 3:32 pm
Welcome to the team Jax, good to have you around.
