1Back to top Go down   RS Mirror pod gasket? Empty RS Mirror pod gasket? Mon Jan 14, 2013 6:18 pm
Whilst assembling a refurbished (e-bay) RS mirror pod this morning, I figured that it was designed for a gasket between the indicator lens and the body. Neither of my bikes have these gaskets, but, out of interest, I made one from 3mm expanded neoprene cord (it's much softer than O ring cord) and it fits and works perfectly.
So, my question is; were any bikes fitted with such a sealing strip or was it a design idea that was scrapped before production?
RS Mirror pod gasket? Sam_0416
It does hold the lens securely and should reduce any vibration wear between the plastic components.
2Back to top Go down   RS Mirror pod gasket? Empty Re: RS Mirror pod gasket? Mon Jan 14, 2013 7:09 pm
sidecar paul wrote:Neither of my bikes have these gaskets,
Strange, it normally should be a gasket there.
Part # 46 63 1 455 046, and if I remember correctly it's of a rather soft material.
3Back to top Go down   RS Mirror pod gasket? Empty Re: RS Mirror pod gasket? Mon Jan 14, 2013 7:32 pm
japuentes
japuentes
Hi there, BMW mirror body parts come with the gasket.
They are also very fragile and tend to pop out on potholes with disregard of the incoming trucks, so a safety line is higly advisable.
Best regards
JAP
RS Mirror pod gasket? 2854237993 1988 K100RS SE/ABS
4Back to top Go down   RS Mirror pod gasket? Empty Re: RS Mirror pod gasket? Tue Jan 15, 2013 6:15 pm
Thanks Inge, as you say, strange that my bikes don't have them, so I'll have to make some for the other pods.
