dmanley
dmanley
Preparing to install a new clutch plate and do a valve clearance adjustment I bought these tools from Kenneth Lively (polepenhollow@yahoo.com). I paid $46.50 (included shipping) for all three. He also makes several other tools for various BMWs. I've seen post for him on the site but thought I'd provide an update.
https://2img.net/h/i1327.photobucket.com/albums/u675/d_manley/IMG_0636_zps8bdaa232.jpg
Daryl
1985 K100RT
nino
I used flomaster (marker) as clutch centering tool, last time. Result very good
dmanley
dmanley
I looked at several other things but $18.50 for an exact match was to good to pass.
Daryl
1985 K100RT
nino wrote:I used flomaster (marker) as clutch centering tool, last time. Result very good
I used a 15mm socket and a 2B pencil.
Worked a treat.
A discussion with RT Halo and Mr K at the Robertson pub about the centering tool.
I thought it was only to align the splines so you could get the gearbox back on. As soon as the clutch lever is pulled the friction plate is free (attached to the gearbox spline) and will give itself any minor adjustments needed.
They had had too much beer and just sat there dribbling at the thought of stripping the rear end.
Discuss
rossco
I have actually aligned it by eye, it isn't that critical to just get the gearbox back on.
I'll have you know that the dribble was because I could see over your shoulder, the barmaid winking at me.
As if you could see anything at all;
Clutch Alignment Tool and Valve Adjustment Tools Sany0219
KKlompy Clutch Alignment Tool and Valve Adjustment Tools 2854237993
Clutch Alignment Tool and Valve Adjustment Tools Au-log10
Have you never savored the bouquet before sipping?.
On a return to the thread, I had a mate turn me up a centering tool out of wood. Hope it works.
have used a broom before....or a cutting thereof , of course.
japuentes
japuentes
I thought it was only to align the splines so you could get the gearbox back on. As soon as the clutch lever is pulled the friction plate is free (attached to the gearbox spline) and will give itself any minor adjustments needed.rossco
Hi Rossco, happy new year.
That's exactly how I think it works, the plate will self center. The alignment tool is intended for a workshop doing the job many times and fast. I use the marker on the tool box.
Best regards
JAP
Clutch Alignment Tool and Valve Adjustment Tools 2854237993 1988 K100RS SE/ABS
Tenox
Tenox
In my recent repairs I had my dad make these tools:
http://kotisivu.dnainternet.net/ajk73/Tools.jpg
4 bolts are for gearbox assembly (but they were not needed since I could not get the starter off and we had to put gearbox on with little downward twist..) 1 bolt there is for that spring system on the cover of gearbox and one in the middle is the clutch alignment tool - worked for us. Big thing on right is for the main seal.
http://kotisivu.dnainternet.net/ajk73/MS_Hammer.jpg
There is a little shoulder on it, so it leaves the seal about 1mm high. Which - I've been told - is the right place for new seals.
BMW K100RT Scrambler (86)
mike d
I understand the latest tool is machined to set the seal at 0.5mm proud of the casing.
Mike
Rick G wrote:I have actually aligned it by eye, it isn't that critical to just get the gearbox back on.
Same here, twice now I've not had to use a clutch arbor tool to centre them. Properly lubed (but not overly) it'll often slip right back where it needs to be. I reckon the trick is in centring the clutch disc as the bolts are being tightened down.
Tenox
Tenox
Mike
OK, but I would be suprised if it really is that precise. I think that whatever from 0 - 1,5mm would do, but if you put it all the way to the bottom, it will leak. But thats just my opinion, not a fact. (Bottom is about 3-4mm off the casing and seal blocks (at least partially) one oil channel too - mine was installed like that and it leaked.
The seal I use is a commercialy available Viton seal that is 8mm wide as against 10mm for the OEM. The sealing lip is 2mm futher rearward than OEM and can be put in level and not go anywhere near blocking the return drain hole. I have not had any problems with them providing I use the Viton compound.
Tenox
Tenox
I meant that if you hammer seal all the way to the bottom it will be 3-4mm inside the casing and that causes problems. I dont think that any seal would be a problem if installed level or up to 1,5mm out of the casing.
rcle6782
rcle6782
Is there any chance of the clutch hub chewing out the gearbox input shaft spline if it isn't aligned properly?
Apparently that can happen to some R series...
walfish
walfish
It would be quite difficult to assemble with the clutch plate mis-aligned, unless you beat the gearbox in with a big hammer.
If all is correct the gearbox slides into position.
I use 2 threaded rods about 80 mm long screwed into the bell housing gearbox mounts, all you need then is slide the box on these 2 rods to align the friction plate.
You will of course need to leave the clutch assembly slightly loose for correct alignment and once it's aligned remove the box, tighten the 6 allen head screws, remount the box on the same 2 rods and then complete the assembly.
 Clutch Alignment Tool and Valve Adjustment Tools 22936
Clutch Alignment Tool and Valve Adjustment Tools Uk-log10
                            88 K 100  0033026 (gone)
                            92 K 1100 LT  6455097 (gone)
The problem with some of the R series was that some of the engineers did fell asleep when the clutch/gearbox was designed.
The clutch hub don't have full contact along the length of the outer end of the gearbox shaft......and the result is more rapid wear, especially the shaft.
kartooo
kartooo
Inge K. wrote:The problem with some of the R series was that some of the engineers did fell asleep when the clutch/gearbox was designed.
Yup, always bothered me about my R1150RT.
i went and spent the big $$ on a Bruno's clutch that is designed to use the full length of input shaft splines.
being a mechanic and knowing this stuff you think about it when going down a lonely rd way away from home..... Shocked
85 k100rt current
04 vulcan 1500 classic sold
07 bonneville black sold
05 fjr1300 sold
04 r1150rt sold
91 k100lt sold
r80rt sold
85 K100 sold
