1Back to top Go down   ATO Wngnutmv Empty ATO Wngnutmv Wed Nov 21, 2012 3:40 pm
gmcq
gmcq
I was looking at your bike in the gallery, did you make the parcel rack yourself?
G
1996 K1100LTIC 0235790
2Back to top Go down   ATO Wngnutmv Empty Re: ATO Wngnutmv Thu Nov 22, 2012 12:30 pm
wngnutmv
wngnutmv
Hey G! Thanks for the question. No, it was on the bike when I got it. It does no appear to be home made. Currently I have just the rack without the passenger back rest (it is a separate piece that can be unbolted). If you're handy at fabricating and want to build one I can send pictures and measurements. It works great for strapping on my lunch cooler when I ride to work!
Mike
"Wingnut"
85 K100RT (VIN 0D50672) 70,000+miles
"Gretchen II" (Gretchen von Gearshiften)
3Back to top Go down   ATO Wngnutmv Empty Re: ATO Wngnutmv Thu Nov 22, 2012 12:30 pm
wngnutmv
wngnutmv
Mike
"Wingnut"
4Back to top Go down   ATO Wngnutmv Empty Re: ATO Wngnutmv Thu Nov 22, 2012 2:04 pm
gmcq
gmcq
Cheers Mike, some photos would be great
G
5Back to top Go down   ATO Wngnutmv Empty Re: ATO Wngnutmv Thu Nov 22, 2012 7:39 pm
The rack is from the US company Reynolds, AFAIK it don`t exist anymore.
6Back to top Go down   ATO Wngnutmv Empty Re: ATO Wngnutmv Thu Nov 22, 2012 10:43 pm
wngnutmv
wngnutmv
This forum never ceases to amaze me! The amount of things that you people know about these bikes is amazing. Will post some pics this weekend.
Mike
"Wingnut"
7Back to top Go down   ATO Wngnutmv Empty Re: ATO Wngnutmv Fri Nov 23, 2012 4:58 am
a company called gearsack made something similar for their gearsack bags, twas a great company in the day 70's and 80's
8Back to top Go down   ATO Wngnutmv Empty Re: ATO Wngnutmv Fri Nov 23, 2012 7:36 am
wngnutmv wrote:This forum never ceases to amaze me! The amount of things that you people know about these bikes is amazing. Will post some pics this weekend.
Why so surprised? I did post this info earlier this year...Post #12.
9Back to top Go down   ATO Wngnutmv Empty Re: ATO Wngnutmv Fri Nov 23, 2012 2:38 pm
gmcq
gmcq
Looking forward to a bit of fabrication! Thanks
G
10Back to top Go down   ATO Wngnutmv Empty Re: ATO Wngnutmv Fri Nov 23, 2012 8:27 pm
wngnutmv
wngnutmv
Here's a few shots that I took today. I can take some with it off in a few weeks if you need some of just the rack. It uses the same bolts at the rear as the pannier brackets. Hope these help.
ATO Wngnutmv IMAG0434
ATO Wngnutmv IMAG0436
ATO Wngnutmv IMAG0437
Mike
"Wingnut"
11Back to top Go down   ATO Wngnutmv Empty Re: ATO Wngnutmv Sat Nov 24, 2012 7:51 am
gmcq
gmcq
Great pics Mike, thanks. Should be simple enough to make. Bending the bar for the support bracket may present a problem. I think my brother has a jig for bending, that and some heat might work. Making two identical will a laugh Razz
12Back to top Go down   ATO Wngnutmv Empty Re: ATO Wngnutmv Sat Nov 24, 2012 8:48 am
A easier solution would be to get a used genuine rack for £65,- from Motorworks.
13Back to top Go down   ATO Wngnutmv Empty Re: ATO Wngnutmv Sat Nov 24, 2012 11:01 am
gmcq
gmcq
Inge K. wrote:A easier solution would be to get a used genuine rack for £65,- from Motorworks.
That indeed would be easier! Problem is it costs £65 and I also need a new battery (current one still starts the bike but I think it is the reason the ABS does not work), a complete battery tray (dont know why it is missing, PO or police maybe),exhaust manifold gasket & removal of two broken exhaust bolts (my fault), handle bar end weights and a heated grip switch ATO Wngnutmv 178468, the list does go on but these are the most pressing.Besides, I have enough steel in the garage I think to make one up and it is a good excuse to go to the garage and tinker Very Happy.
14Back to top Go down   ATO Wngnutmv Empty Re: ATO Wngnutmv Sat Nov 24, 2012 11:27 am
gmcq wrote:I also need a new battery (current one still starts the bike but I think it is the reason the ABS does not work),
If the battery is to weak, you would get following symptom:
When you switch the ignition on, both warning lamps would flash together.
When you then press the starter button, the warning lamps starts to flash alternately (due to the voltage drop).
And the ABS won`t continue with the self test, since a fault is detected.
The remedy is:
Switch the ignition off when the bike is rolling, then back on and start the bike in gear w/o using the starter (then you don`t get the voltage drop).
And the ABS would function as normal.
15Back to top Go down   ATO Wngnutmv Empty Re: ATO Wngnutmv Sat Nov 24, 2012 12:48 pm
gmcq
gmcq
The remedy is:
Battery aint the problem then! But no fault code stored in the memory, new sensor on front, back one works, gap set correctly & only one warning light flashes when driving. Any ideas?
16Back to top Go down   ATO Wngnutmv Empty Re: ATO Wngnutmv Sat Nov 24, 2012 1:46 pm
gmcq wrote:Battery aint the problem then! But no fault code stored in the memory, new sensor on front, back one works, gap set correctly & only one warning light flashes when driving. Any ideas?
Low voltage would store a code 5..............
Sorry but I don`t think I can help you with this one,,,if I remember correctly we already gone through this earlier, in another thread....and I got no new ideas since then.
Only issue I remember with only one light flashing, is from another forum...where the problem was the connection to the rear sensor...think I did post a link to this earlier.
Does both warning lights flash when you switch on the ignition?
And if, at which point only the single warning lamp starts to flash?
17Back to top Go down   ATO Wngnutmv Empty Re: ATO Wngnutmv Sat Nov 24, 2012 2:55 pm
gmcq
gmcq
Yes you have been through this before with me, I am now standing at the back of the room facing the corner for now paying attention Embarassed
Only one light flashes, the left one, continuosly from turning the key.
G
18Back to top Go down   ATO Wngnutmv Empty Re: ATO Wngnutmv Sat Nov 24, 2012 3:02 pm
Both should flash from the start, is the ABS warning relay removed...or the ABS ECU disconnected?
19Back to top Go down   ATO Wngnutmv Empty Re: ATO Wngnutmv Sat Nov 24, 2012 3:11 pm
gmcq
gmcq
No I dont think so but will check first thing in the morning. Thanks Inge
G
20Back to top Go down   ATO Wngnutmv Empty Re: ATO Wngnutmv Sat Nov 24, 2012 4:17 pm
The left warning lamp is connected via the warning relay,
so if it flashing.....the relay is present, and the ECU is connected.
The right warning lamp get it`s signal (ground) directly from the ECU, to check signal...measure voltage at contact 6 (+) and signal (-) at contact 12 at the cluster connector...ignition on...should go on/off...easiest with a analogue meter.
If no signal is present,check the wiring....white/black wire from pin 18 on the ECU to pin 12 at the cluster. (measure the wiring between these two contacts, using resistance)
If signal is present, easiest way to check if the bulb is OK, would be to measure the resistance between pin 6 and 12 at cluster (connector removed)....if the bulb is OK, you should read a few ohms.
If all is found to be OK, but no signal........it seems like the ECU don`t sends out a signal.........time to contact Tosi.
21Back to top Go down   ATO Wngnutmv Empty Re: ATO Wngnutmv Sat Nov 24, 2012 6:16 pm
twincarb
twincarb
if we are talking ABS 1.5 when you turn the ignition on only the ABS lamp flashes the ! stays solid until it's checked both the front and rear brake.
If there is a fault of any kind with the ABS then both lights flash at the same time in a really annoying way until you press the ABS switch and both lights will stay on solid for 10 mins then both flash....
If we are talking about ABS 2 then I shall Embarassed ATO Wngnutmv 652573 Surprised-o:
Yamaha Thundercat
ATO Wngnutmv 169042ATO Wngnutmv 169034
22Back to top Go down   ATO Wngnutmv Empty Re: ATO Wngnutmv Sat Nov 24, 2012 6:22 pm
twincarb wrote:If we are talking about ABS 2 then I shall Embarassed ATO Wngnutmv 652573 Surprised-o:
Since it is a -96 K11..........
23Back to top Go down   ATO Wngnutmv Empty Re: ATO Wngnutmv Sun Nov 25, 2012 9:31 am
gmcq
gmcq
Inge K. wrote:The left warning lamp is connected via the warning relay,
No signal from ECU it seems, getting resistance between pin 18 & 12 and with 6 & 12. Whats Tosis address? At least we now know whats wrong. May wait to mid winter. Thanks for all your patience and help Inge
G
24Back to top Go down   ATO Wngnutmv Empty Re: ATO Wngnutmv Sun Nov 25, 2012 10:11 am
Here is a link to Tosi`s page.
Look at the different this and that to check on the page.
You could drop him a mail about the symptom(s) and no code stored.
Could be that he have some advice/idea.
Good luck!
