1 Headlight survives entire bike being turned off Wed Oct 31, 2012 5:04 am
Jhepburn
This is odd: Got home last night, turned off, put bike on centrestand ... headlight is still on. What? I triple-checked the key position, flicked all the light-associated switches just in case - headlight stayed on. The light off switch worked, but then the high-beam flasher also worked, turning on the light - with the ignition turned off.
Thankfully, the bike started again today, so having turned the light off manually the battery wasn't killed.
I haven't started investigating this yet, so I haven't looked at any of the wiring diagrams. I'll have time tomorrow. I'm thinking a reliable short has established, bypasing the ignition switch? Or is the connection managed by a relay, not a physical break in the circuit, and the relay may be fried?
I haven't cleaned the starter motor yet (http://k100rt.aforumfree.com/t4530-now-what-the-hell-starting-problem - that problem has happened three times now, in four weeks, so I've got the kit but haven't had a spare day to address it) so hey, I guess weird electrical problems could have any cause :pirat:.
