1Back to top Go down   Replacing front screen Empty Replacing front screen Mon Oct 08, 2012 11:32 am
BillOwens
BillOwens
Any ideas how this can be done without dismantling the fairings, I have the new screen and am ready to go but it looks a big job
It's 1984k100RS Replacing front screen 178468
1984 BMW K100 RS black,90,000km, 1982 Ducati Pantah 600SL 2,000km since restoration, 1949 Velocette Mac 350, undergoing restoration
http://www.wdmoc.com
2Back to top Go down   Replacing front screen Empty Re: Replacing front screen Mon Oct 08, 2012 11:36 am
Is the screen electric? I dont have electric and it come off to clean it by unscrewing the seven screws and no discmantling of the faining.
If it is electric I am sure someone will point you in the right direction.
92KK
3Back to top Go down   Replacing front screen Empty Re: Replacing front screen Mon Oct 08, 2012 12:06 pm
Thats it Bill 7 screws and 4 on an electric.
4Back to top Go down   Replacing front screen Empty Re: Replacing front screen Mon Oct 08, 2012 4:06 pm
Remove the inner panel at each side of the screen (four screws).
To get the screen off, it`s usually also needed to loosen the center part.
Then you also need to remove the knee pads (three screws each side) and remove the small plastic bits between knee pads and center part........to get acces to the center part mounting screws.
5Back to top Go down   Replacing front screen Empty removing screen Mon Oct 15, 2012 10:16 am
BillOwens
BillOwens
Being an RS all I had to do was remove 2 inner panels as Inge suggested, take the six screws out (only three were attached) and slide it out!
New screen is in, i've got to get a new set of screws from the boltman and i'm putting little rubber grommets on them and all should be OK
thanks for the help
6Back to top Go down   Replacing front screen Empty Re: Replacing front screen Sun Oct 28, 2012 10:28 pm
Biagio
Biagio
BillOwens wrote:Being an RS all I had to do was remove 2 inner panels as Inge suggested, take the six screws out (only three were attached) and slide it out!
thanks for the help
Bill,
can i ask you were did you take the screen? I can't find it nowhere.
7Back to top Go down   Replacing front screen Empty purchase of screen Mon Oct 29, 2012 10:44 am
BillOwens
BillOwens
its a long way from you, but Munich cycles in Perth Australia have the genuine item in stock, cost $320 AU
Hope that helps
Regards Bill Owens
8Back to top Go down   Replacing front screen Empty Re: Replacing front screen Mon Oct 29, 2012 11:18 am
Also Moto Bins and Motorworks got them,.......a bit expensive....
9Back to top Go down   Replacing front screen Empty Re: Replacing front screen Mon Oct 29, 2012 11:29 am
10Back to top Go down   Replacing front screen Empty Re: Replacing front screen Mon Oct 29, 2012 12:03 pm
Toto_jp
BillOwens wrote:its a long way from you, but Munich cycles in Perth Australia have the genuine item in stock, cost $320 AU
Hope that helps
Regards Bill Owens
Bill should of gone to Motorworks new screen, new lip, new lip screws and washers under $250 delivered took 7 days
K100 RS 1986
11Back to top Go down   Replacing front screen Empty Re: Replacing front screen Mon Oct 29, 2012 5:36 pm
Biagio
Biagio
Uazzzzzz it's a lot of money!
I will keep mine then. I'll try to polish it a bit...
12Back to top Go down   Replacing front screen Empty Re: Replacing front screen Mon Oct 29, 2012 7:26 pm
GerryP
GerryP
I used jeweller's rouge on mine.
It takes a fair bit of elbow grease and its really messy but my screen came up like new!
Safe riding Cool,
Gerry Parnham
K1100LT (1993) in Silk Blue/Cream
http://gerryparnham.com
