1Back to top Go down   Lower Fairing Empty Lower Fairing Mon Sep 17, 2012 12:16 am
wngnutmv
wngnutmv
Can you guys tell me if the lower fairing (see attached photo) will fit my 85 RT? If so, where might I find one? Thanks in advance!
Lower Fairing Lowercover
Mike
"Wingnut"
85 K100RT (VIN 0D50672) 70,000+miles
"Gretchen II" (Gretchen von Gearshiften)
2Back to top Go down   Lower Fairing Empty Re: Lower Fairing Mon Sep 17, 2012 12:20 am
You can still buy the belly pan in pieces (all mounting hardware and primed plastic) from BMW. They have them in the German warehouse still, but for major bucks. It will fit your RT. I have been looking for one for my RS for yonks. I'll arm wrestle you for it if you find one.
3Back to top Go down   Lower Fairing Empty Re: Lower Fairing Mon Sep 17, 2012 7:58 am
If you try to search a used engine spoiler (hard to find) but they show up now and then.
It`s two versions, 2V and 4V.
I would prefeer the 2V, as the bracket is easier to remove when needed.
The 4V bracket using the same mounting point as the lower LHS fairing on the RT.
The cutout for the exhauster is also smaller on the 2V engine spoiler.
5Back to top Go down   Lower Fairing Empty Re: Lower Fairing Mon Sep 17, 2012 8:35 am
ridefar wrote:there is one for sale on ebay.
That`s the 2V version......not exactly mint condition, and mounting parts missing.
6Back to top Go down   Lower Fairing Empty Re: Lower Fairing Mon Sep 17, 2012 8:59 am
Bit of a roughie but you can't be too pickie when you want one of them.
7Back to top Go down   Lower Fairing Empty Re: Lower Fairing Mon Sep 17, 2012 9:58 am
I priced out the bits from der Vaterland the other day, factory BMW belly pan in prime and all necessary bits for mounting, at just over Five Hunnerd US Greenabacks, my cost from the dealership where I'm currently engaged in gainful employment. Too much for what you get, But to the right person, and a bike that's resto quality...that's small change compared to what you'd spend to resurrect a secondhand one from a boneyard or private sale.
8Back to top Go down   Lower Fairing Empty there is one for sale on ebay Mon Sep 17, 2012 2:22 pm
ridefar
ridefar
actually it did not tell the whole story. It is mine, from a barn find that I am riding. Selling some of the stuff I'm not going to use. I probably have the mounting bolts.
9Back to top Go down   Lower Fairing Empty Re: Lower Fairing Mon Sep 17, 2012 6:05 pm
wngnutmv
wngnutmv
Thanks everybody! Ridefar, is the condition of the one you have something that could be refurbished? It's fiberglass, right? Or is it plastic?
Ridefar, I placed a bid, we'll see what happens. Would appreciate as much hardware as you can find for it. Any chance you have a good headlight that would fit my RT, mine has a rock chip in it. Thanks!
Mike
"Wingnut"
10Back to top Go down   Lower Fairing Empty Re: Lower Fairing Mon Sep 17, 2012 6:17 pm
It`s not fibreglass. It was some kind of hardened foam material.
I think it was pressure molded polyurethan foam, but I`m not quite shure of that.
11Back to top Go down   Lower Fairing Empty Re: Lower Fairing Mon Sep 17, 2012 6:25 pm
wngnutmv
wngnutmv
hmmm, not familiar with making repairs to that type of material, and it looks like it needs some.
Mike
"Wingnut"
12Back to top Go down   Lower Fairing Empty Re: Lower Fairing Tue Sep 18, 2012 12:17 am
ridefar
ridefar
hey wngnut,
I will try and find any of the hardware for that belly pan. I do not know what material it is. It is not fiberglass. I thought it was plastic but IngeK seems to be right about these K models quite often. You may find that its not in as bad as one might think. And I don't think these things are easy to find.
I do not have a headlight.
Thanks for the bid.
13Back to top Go down   Lower Fairing Empty Re: Lower Fairing Tue Sep 18, 2012 10:18 am
wngnutmv
wngnutmv
A friend of mine owns a body shop, so I can get some advice from him on getting it to look good and match my color. Thanks for checking on the hardware.
Mike
"Wingnut"
14Back to top Go down   Lower Fairing Empty Re: Lower Fairing Tue Sep 18, 2012 10:23 am
ridefar
ridefar
OK Mike, I hope you get it and are happy with it.
15Back to top Go down   Lower Fairing Empty CAN ANYONE TELL ME????? Sat Oct 20, 2012 3:24 am
ibjman
ibjman
I have one of these that I'm putting on an 85 rs. The mounting bracket is bolted to 2 rubber threaded cusions on the left side and has 2 rubber grommets on the right side that slide over 2 threaded studs that stick out of the right side of the oil pan threaded holes front & rear. Once the bracket is mounted up it has some "vibration room" to kinda "float" on the rubber mounts & grommets.
When I got the bracket, the left rear nut insert was missing from the spoiler mounting hole as like I've seen on other used examples. I welded a nut on the inside of that hole to match the other 3.  My question is: Should there be a nut in that hole to bolt the plastic spoiler to or some kind of additional bracket?
When my spoiler is bolted up, the left rear corner seems abnormally "spingy" (up & down movement).....as if it could use an additional support bracket to something on the engine on that corner.
I considered building an additional "stiffener bracket" to support the L/R corner.......perhaps anchored to the #4 header pipe flange studs.
I should note that when I  received the bracket used, there was a cut-out area in the bottom left rear of the mounting bracket (probably for a curved down header pipe- clearance)?  I welded a sheet metal patch in the cut out area......perhaps that needs to be better re-inforced to avoid the up & down "flex" in the left rear.  Do other people experience this same movement at the left rear of the spoiler/bracket? If so, has anyone developed a fix to make the left rear corner stiffer?
16Back to top Go down   Lower Fairing Empty Re: Lower Fairing Sat Oct 20, 2012 12:39 pm
ibjman wrote: I should note that when I received the bracket used, there was a cut-out area in the bottom left rear of the mounting bracket (probably for a curved down header pipe- clearance)? I welded a sheet metal patch in the cut out area......perhaps that needs to be better re-inforced to avoid the up & down "flex" in the left rear. Do other people experience this same movement at the left rear of the spoiler/bracket? If so, has anyone developed a fix to make the left rear corner stiffer?
This is how a unmodified 2V bracket look like at LHS.
(I`ll guess that yours have been used on a 4V earlier).
Lower Fairing Hpim1014
17Back to top Go down   Lower Fairing Empty Unmodified 2V bracket Sun Oct 21, 2012 2:21 am
ibjman
ibjman
Thanks for your reply & photos. It looks as I had imagined mine should. Because I was a little unhappy with the up and down movement at the left rear, I went ahead and installed a stand-off bracket to that corner mounting bolt running back & up to an unused threaded hole on the bottom rear of the cylinder head. Rock solid now.
18Back to top Go down   Lower Fairing Empty Re: Lower Fairing Sun Oct 21, 2012 1:54 pm
wngnutmv
wngnutmv
Worked on mine yesterday, finally. Removed all the old paint and filled in a few bad spots. I think it's ready for primer and paint. Test fitting was done last week-end. Can't wait to get it finished.
Mike
"Wingnut"
19Back to top Go down   Lower Fairing Empty Re: Lower Fairing Sun Oct 21, 2012 2:14 pm
ibjman wrote: I went ahead and installed a stand-off bracket to that corner mounting bolt running back & up to an unused threaded hole on the bottom rear of the cylinder head.
That hole is used to mount the bracket on the 4V models,
which have a different bracket due to the headers needs more space.
