Number of posts : 7968
Done this many times and its much easier with the lower left panel removed.
You need to look at the radiator grille from the left side and see there are 3 screws into the lower right hand side panel. They are hard to see but they are there. I undo those screws first, along with the ones on the laft side of the tank that go through the baffle, accessed after you remove the fairing left leg panel and storage box. There is a locating tab at the front top of the left faifing panel so that will hold it in place. Then you remove the bracket mount 10mm bolts [accessed after leg panel is removed] holding the panel and it should come free,
At this stage it takes me just 10 minutes to get all the stuff out of the way.
With that done you have free access to the fuel hose connections and the plug connector to the fuel tank that is located front left of the bolted tank on early Ks.
If you are removing the right hand lower panel there is a bottom screw fixing to the radiator panel from underneath at the very front, very easily missed.
1971 Yamaha 125 YAS-1
