1Back to top Go down   Resistance is futile...... Empty Resistance is futile...... Sat Oct 06, 2012 9:02 am
Lucky Lou
Lucky Lou
When i had the battery off to check it i tested the resistance between the live terminal and earth with the ignition off and found a reading of 56 ohms, i thought this strange so i tested my old Airhead and the circuit was totally open no reading (as expected).
I returned to the K retested pulling all the fuses and the reading remained constant at 56 ohms, i know the clock circuit is on independent of the ignition but i would have thought that it would be on a fused circuit so i just wondered if anyone else has tested for this and what reading they got as 56 seems pretty low to me and could be the cause of my previous starting troubles.
Lou
2Back to top Go down   Resistance is futile...... Empty Re: Resistance is futile...... Sat Oct 06, 2012 9:14 am
you have abs lou ?
3Back to top Go down   Resistance is futile...... Empty Re: Resistance is futile...... Sat Oct 06, 2012 9:31 am
Lucky Lou
Lucky Lou
charlie99 wrote:you have abs lou ?
Yes but i have pulled the relay as its showing a fault, i am getting this reading with the ignition off though ??
Lou
4Back to top Go down   Resistance is futile...... Empty Re: Resistance is futile...... Sat Oct 06, 2012 9:39 am
time to start pulling fuses till you find the circuit that has that load ...
as i said earlier ...folks do some interesting mods ..non documented some times ...and often in an incorrect way
5Back to top Go down   Resistance is futile...... Empty Re: Resistance is futile...... Sat Oct 06, 2012 9:43 am
Lucky Lou
Lucky Lou
Not noticed any unusual wiring but i am getting the 56ohms with the fuses out.
Lou
6Back to top Go down   Resistance is futile...... Empty Re: Resistance is futile...... Sat Oct 06, 2012 10:08 am
ouch !
that could make it a bit harder to find
better wait till ingesat comes over ...he may know of later series options fitted ! giggle
but to my way of thinking they should be behind the fuses ...
7Back to top Go down   Resistance is futile...... Empty Re: Resistance is futile...... Sat Oct 06, 2012 11:06 am
Lou there are a number of places that can be unpluged to isolate it futher. Unplug the ECU, ICU which is under the tank right up front below the top frame tube and both left and right handlebar switches, these unplug from the main harnes under the tank.
You possibly have a crushed harnes in some place and the most likely place is at the steering head. Wuold also pay to unplug the instrument panel. Do them one by one and check after each one and inspect the wire harnes all over for crushing or abrasions.
From what you have done already I reckon you know what I am getting at.
8Back to top Go down   Resistance is futile...... Empty Re: Resistance is futile...... Sat Oct 06, 2012 11:30 am
Lucky Lou
Lucky Lou
Rick G wrote:You possibly have a crushed harnes in some place and the most likely place is at the steering head. Wuold also pay to unplug the instrument panel. Do them one by one and check after each one and inspect the wire harnes all over for crushing or abrasions.
Yup going to pull the tank off tomorrow and have a poke arround would have thought the circuit would be open with the fuses out thanks for the help.
Lou
9Back to top Go down   Resistance is futile...... Empty Re: Resistance is futile...... Sat Oct 06, 2012 2:21 pm
I would have started with disconnecting the alternator, then the ignition switch.
Any aftermarket euquipment mounted?
10Back to top Go down   Resistance is futile...... Empty Re: Resistance is futile...... Sat Oct 06, 2012 2:44 pm
Lucky Lou
Lucky Lou
Inge K. wrote:I would have started with disconnecting the alternator, then the ignition switch.
Does the alternator have an exiter circuit ? I have played with Airheads for years but i am new to these new fangled K,s
No extras bog standard RT just wondered if anyone else has ever tested to earth and got a reading for a bike with no problems so i would have an idea what the reading should be.The cooling fans dont work so i will check that circuit when i get the tank off for a poke around.
Lou
11Back to top Go down   Resistance is futile...... Empty Re: Resistance is futile...... Sat Oct 06, 2012 2:51 pm
Lucky Lou wrote:[Does the alternator have an exiter circuit ? I have played with Airheads for years but i am new to these new fangled K,s
Yes, the rotor is the exciter.
The alternator is a identical to Bosch models used in cars......years ago.
Last edited by Inge K. on Sat Oct 06, 2012 2:57 pm; edited 1 time in total (Reason for editing : Adding info.)
12Back to top Go down   Resistance is futile...... Empty Re: Resistance is futile...... Sat Oct 06, 2012 2:54 pm
Lucky Lou
Lucky Lou
s
Mmmm that will be worth checking then
Thanks Lou
13Back to top Go down   Resistance is futile...... Empty Re: Resistance is futile...... Sat Oct 06, 2012 3:08 pm
ReneZ
ReneZ
Definitely have a look at the alternator. In an other threat we found an alternator faulty, drawing 2 amps from the battery with all the fuses out. Just pull the plug and see what it does.
Rene
BMW K100 - 1985 (0030029) Scotland Resistance is futile...... Rain
14Back to top Go down   Resistance is futile...... Empty 56 ohms Fri Oct 19, 2012 10:32 am
sven k100
sven k100
could that reading be the ignition kill circuit, with the low tension side of the circuit earthed via kill switch or ignition switch ?
Similar topics
» Oil Change
