1Back to top Go down   warm up with start button Empty warm up with start button Mon Oct 29, 2012 4:48 am
nino
Hello all, here temp is 15 in the morning, 20 at midday. Choke gives too much revs, so I started to use start button for 15 to 20 sec after start up. Bike responds just as I like. But I am not shure any damage possible on electric or fuel system?
Regards
2Back to top Go down   warm up with start button Empty Re: warm up with start button Mon Oct 29, 2012 6:16 am
hi nino ...i believe that there is a starter motor lockout (stops the relay from operating ) above a certain revs of the motor but not sure at what revs this occurs . this should prevent any mechanical damage .
otherwise the start signal enriches the fuel mix and a few here have suggested that it wont hurt anything ...
personally i have not tried this ..
3Back to top Go down   warm up with start button Empty Re: warm up with start button Mon Oct 29, 2012 10:33 am
If the engine is running above 770 RPM then the starter relay wont opperate as the ICU removes the earth from it.
4Back to top Go down   warm up with start button Empty Re: warm up with start button Mon Oct 29, 2012 12:32 pm
That was close, Rick...according to bmw it`s 711 rpm... but what does it matter.....
5Back to top Go down   warm up with start button Empty Re: warm up with start button Mon Oct 29, 2012 2:23 pm
Thanks I will put that in my memory bank and probably forget again. My poor brain is cloged with 62 years of garbage and I just can't get rid of any of it to make room for more.
6Back to top Go down   warm up with start button Empty Re: warm up with start button Mon Oct 29, 2012 2:25 pm
External disc?............rather cheap these days.
7Back to top Go down   warm up with start button Empty Re: warm up with start button Mon Oct 29, 2012 2:31 pm
I tried plugging it in and it hurt too much and .no....no Too much information.
