1 Non starting K100 after 5 years unused. Sat Jun 20, 2009 6:40 am
Mi Amigo
My BMW K100
RT (1985 vintage) has been off the road in my garage for about 5 years whilst I
slowly repaired the fairing. This is now complete but I am now having trouble
starting the engine. Having stood for 5
years I assumed that the petrol had gone stale so I drained the tank and put
some fresh fuel in. I have checked the battery connections as in the past I
have had trouble with K100 and K75 starting due to poor earth connections and
semi flat batteries. I have currently got it connected to a Metro car battery-
fully charged. I can hear thye fuel pump running, and if I remove the rubber
hose from the rear of the fuel rail there appears to be plenty of pressure
here. On taking the spark plugs out I am getting a nice bright spark but I noticed
that the plugs are bone dry- indicating that no fuel is being spat into the
cylinders.
At this
stage I checked out Crazy Frog’s very useful fault finding chart and tips. I
have placed a led (in series with a 470 ohm res) across the end injector and
this flashes once per revolution as it should. I have checked out the voltages
expected at the connector to the fuel injection computer and the only anomaly I
can see here is that when I turn the engine over the signal at pin 4 (starter
running) reads 8 volts whereas in Bert’s table this should read 12 volts. I
have had an exchange of e-mails with Bert and he assures me that this voltage
is not critical. The ground to injectors
resistance at pin 12 reads 4 ohms, as it should with four injectors in parallel
across this line.
So at the
moment I am down to removing the injectors- which of course involves removing
the lower half of the RT fairing again.
I thought it worth raising this problem on here in case anyone knows any
common starting problems with K100s after they have been unused for 5
years? The bike started and worked
perfectly well after it was driven into the garage all those years ago.
Any
suggestions please?
cylinders.
At this
across this line.
So at the
Any
suggestions please?
