1Back to top Go down   Fuel filter out Empty Fuel filter out Tue Aug 21 2012, 13:27
nino
I didnt find original fuel filter, but friend of mine offered Ducati type filter, black one. I was worried about the black color immersed in fuel, so decided to mount it out of tank. Voila 60 plus 60 cm of hose, few plastic straps, filter on the left side under the tank. Upper hose follow space under the tank, hose down follow the fuel rail. It works - easy to change filter next time.
Regards
Fuel filter out Filter10
2Back to top Go down   Fuel filter out Empty Re: Fuel filter out Tue Aug 21 2012, 13:37
This looks much better:
3Back to top Go down   Fuel filter out Empty Re: Fuel filter out Tue Aug 21 2012, 13:39
Fuel filter out 44271
4Back to top Go down   Fuel filter out Empty Re: Fuel filter out Tue Aug 21 2012, 13:40
nino
I knew....
5Back to top Go down   Fuel filter out Empty Re: Fuel filter out Tue Aug 21 2012, 16:22
Nino, you`re kind of excused....................
Fuel filter out Hpim0914
6Back to top Go down   Fuel filter out Empty Re: Fuel filter out Tue Aug 21 2012, 16:27
nino
I knew...
7Back to top Go down   Fuel filter out Empty Re: Fuel filter out Fri Aug 24 2012, 10:45
nino
Hello, more on heat insulation. Here is 35 degrees stil, so I tried desperately to insulate excessive heat. I added some rubber foil under the lower part of inner fairing. Thats 4 milimeter black foil used for floor in buses and public places. I cut it in form of inner fairing from bottom of air filter housing to bottom of inner fairing and glued with strong cianoacrylic glue.
Regards
Fuel filter out Folija11
Fuel filter out Lijafo10
8Back to top Go down   Fuel filter out Empty Re: Fuel filter out Fri Aug 24 2012, 10:47
nino
nino wrote:Hello, more on heat insulation. Here is 35 degrees stil, so I tried desperately to insulate excessive heat. I added some rubber foil under the lower part of inner fairing. Thats 4 milimeter black foil used for floor in buses and public places. I cut it in form of inner fairing from bottom of air filter housing to bottom of inner fairing and glued with strong cianoacrylic glue.
Regards
Uuups, I send this on wrong post. It had to go to" heat insulation"
9Back to top Go down   Fuel filter out Empty Re: Fuel filter out Fri Aug 24 2012, 17:51
kfilipow
kfilipow
Ok on the wrong place Nino, keeps everybody reading all the posts. Both are good ideas, especially the filter. Anyone see any disadvantage to this filter install? Definitely easier maintenance. Let us know how the insulation works Nino.
Keith
10Back to top Go down   Fuel filter out Empty Re: Fuel filter out Fri Aug 24 2012, 18:25
nino
I think it definitely works. Very hot here, probably more than 35. I drove 50 kms this afternoon in shorties and sandals and it was really OK. Thats it finally. Keith check post heat insulation with photos of upper part of inner fairing and insulation of that part with rubber stripe (for car window).
Regards
11Back to top Go down   Fuel filter out Empty Re: Fuel filter out Sat Aug 25 2012, 05:27
Am I right in saying the filter is after the injectors? I see no other return line.
12Back to top Go down   Fuel filter out Empty Re: Fuel filter out Sat Aug 25 2012, 05:33
nino
K75cster wrote:Am I right in saying the filter is after the injectors? I see no other return line.
Sorry, didnt understand your question
13Back to top Go down   Fuel filter out Empty Re: Fuel filter out Sat Aug 25 2012, 06:45
Is the fuel filter on the return line, from the injector rail to the regulator?
14Back to top Go down   Fuel filter out Empty Re: Fuel filter out Sat Aug 25 2012, 07:13
I would say he has extended the fuel delivery line out to there to put the filter there.
A good idea, if you extend both lines then you can get the tank off without taking all the plastic off, also extend the wire harness to the rear of the tank.
On the K1100 you can pull the tank straight back and access all the under tank stuff without any major job.
15Back to top Go down   Fuel filter out Empty Re: Fuel filter out Sat Aug 25 2012, 07:22
I was at a loss i thought he may have reversed the flow but asked the question rather than sit here speculating, I guess it would not hert to reverse the flow through the fuel rail????
16Back to top Go down   Fuel filter out Empty Re: Fuel filter out Sat Aug 25 2012, 07:31
On the K1100 it goes the opposite way to K100.
The delivery line goes to the back of the rail then from front to FPR then from FPR up between #2 & #3 TB and back to the tank. Getting the tank off is just so easy.
17Back to top Go down   Fuel filter out Empty Re: Fuel filter out Sat Aug 25 2012, 08:30
nino
Yes, I removed fuel filter from tank connected hose directly, than extended the main fuel line and mounted the filter outside. I didnt touch reverse line from pressure regulator to tank at all.
Regards
18Back to top Go down   Fuel filter out Empty Re: Fuel filter out Mon Aug 27 2012, 05:32
It;s a good job Nino.
19Back to top Go down   Fuel filter out Empty Re: Fuel filter out Mon Aug 27 2012, 06:18
Erman
Erman
Rick G wrote:I would say he has extended the fuel delivery line out to there to put the filter there.
+1
To ease removal of tank, I put in a snap connector on the line from tank to rail.
Fuel filter out 82-579_l
Bikes:
1984 BMW K1000RS
1984 Yamaha XJ750 Seca
20Back to top Go down   Fuel filter out Empty Re: Fuel filter out Mon Aug 27 2012, 20:53
kfilipow
kfilipow
Erman, I like the idea. the best price I have found is about $55.00 usd ea. Thats for the plastic. Anyone have an opinion about the benefits of plastic vs the metal disconnects and is there a source that is less expensive?
Keith
21Back to top Go down   Fuel filter out Empty Re: Fuel filter out Mon Aug 27 2012, 21:10
Hey Keith, I found this today on an unrelated search.
Beemerboneyard
22Back to top Go down   Fuel filter out Empty Re: Fuel filter out Mon Aug 27 2012, 22:51
I just got finished replacing the two plastic male portions of the fuel tank quick disconnects on my Big GS. They leak and eventually break. BMW has made the new version metal (for some years now), but have retained the plastic female side, which hardly ever break.
If you go for quick disconnects in either plastic or metal be sure that both sides are rated for fuel pressure!
23Back to top Go down   Fuel filter out Empty Re: Fuel filter out Tue Aug 28 2012, 21:25
kfilipow
kfilipow
Thanks Rossco. I have been looking at these for a while. Just waiting on confirmation that this was the way to go. Been having to remove my tank often recently trying to chase down a ghost short. Keith
24Back to top Go down   Fuel filter out Empty Re: Fuel filter out Wed Aug 29 2012, 15:32
This is how I did mine on the outfit and solo.
http://k100rt.aforumfree.com/t3308-fuel-line-connectors
25Back to top Go down   Fuel filter out Empty Re: Fuel filter out Thu Aug 30 2012, 04:04
Erman
Erman
kfilipow wrote:Erman, I like the idea. the best price I have found is about $55.00 usd ea. Thats for the plastic. Anyone have an opinion about the benefits of plastic vs the metal disconnects and is there a source that is less expensive?
Keith
Thanks!
Here is my solution. I only managed to put one quick release (it's all I had laying around) so far. Planning on putting one on the return hose as well. The plastic works for me. I've had one on the Seca for over a year with no leaks.
Fuel filter out 7885833800_d9e062d4d0
Bikes:
1984 BMW K1000RS
