1 Brake bleeding trouble Tue Aug 28, 2012 5:19 pm
giles4060
Evening all,
Having some fun bleeding the brakes. Bought a cheap vacuum pump to bleed the brakes but the nozzles supplied for the bleed nipples were not great qaulity so ended up introducing alot of air into the modulator and caliper on the rear brake. The brake pedal is now lifeless and rear brake does not work at all.
Anyway I binned the cheap plastic fittings and used a rubber hose. All attachments are now good and snug so no leaks in the system and a good vacuum created by the pump. However now I am unable to get anything from either bleed nipple despite a good pressure on the vacuum gauge, no air leaks and a full resevoir with the lid off.
Any ideas what I have done?
Giles
K100 RS 1991
R80 GS 1990
