1 K100 Poor Throttle Response Tue Aug 28, 2012 6:02 am
ToGGoT
Hi guys,
Rather than revive my old thread which is now almost a year old, and a bit cluttered, i think starting a new one might be more appropriate, as i have now managed quite a lot more diagnostic than before. The bike has been sat for almost a year while i moved house, etc etc, but now i just want to get it fixed!
The Background:
Bought the bike (1985 K100 RT) off ebay, non-runner, in boxes. Engine turned out to be seized, so full strip and rebuild with new rings.
Bike now runs, smokey on startup, but nothing unusual, and that clears quickly as it warms up. Power seems there, but if you twist the throttle quickly, or try to really load up fast, the bike bogs, and unless you back off, it will die.
Things wot i have tried:(!!)
New Fuel, Pump, Filter, Hoses, Regulator, Injectors pro cleaned and tested, fuel pressure is good.
New Air filter, breather hose, TPS tested and set, vacuum switch removed, throttle bodies balanced.
Replaced MAF, ECU, and Ignition unit with known good spares.
Removed and tested Water temp sensor - good.
New HT leads, Plugs, and spark-tested each coil output - getting healthy sparks off each.
Compression is good, and consistent across all four cylinders, and advancing the timing slightly makes no difference.
The plugs are slightly sooty, which makes me think the fuel mixture is too rich, but i cant think what else is going to be affecting it.
Anyone got any ideas? Open to all sensible suggestions at this point!
I get such a good feeling riding this bike, but this problem is like banging your head against a wall!lol!
ToGGoT
The Background:
ToGGoT
