1Back to top Go down   Center stands Empty Center stands Tue Aug 07, 2012 7:58 pm
BooG
BooG
Are center stands interchangeable between K's??
2Back to top Go down   Center stands Empty Re: Center stands Tue Aug 07, 2012 8:20 pm
caferacer62
caferacer62
I'm not an expert on this Boog but Charlie has a K1100 stand on his.
I'm sure someone on here nows a bit more.
Bert 2.0
Center stands 170874
3Back to top Go down   Center stands Empty Re: Center stands Tue Aug 07, 2012 8:33 pm
The 75 and 100 stands are interchangeable though some are different as in straight leg centre stands and curved leg centre stands, it appears the 110's are also able to be a bolt on with what charlie had on his, why do you ask??
4Back to top Go down   Center stands Empty Re: Center stands Tue Aug 07, 2012 10:46 pm
BooG
BooG
Centre stand broke off at a petrol station!! Got a replacement off ebay. Took it apart to clean, and the stands are different, but the cradles which bolt to the bottom of the bike are standard, so should fix. Famous last words!!
5Back to top Go down   Center stands Empty Re: Center stands Wed Aug 08, 2012 12:55 am
Do a google search on the Portal page Boog and you'll get a lot on the subject on the forum. I'm not qualified to comment on k75 stands but early k100 ones had a weak spot and tendancy to break.
K1100 will fit no problem but you need the side stand as well, the k100 is not interchangeable with it. I've got a k1100 stand on my k100 a bit easier to get the bike onto but a bit harder to get it off!
Any idea what the flea bay one is off?
88KE
Center stands Ir-log1188....May contain nuts!Center stands Ir-log11
K75RTP - 1994
6Back to top Go down   Center stands Empty Re: Center stands Wed Aug 08, 2012 1:05 am
BooG
BooG
Did a bit of chopping and changing bushes/bolts and the like and its come good! Not sure what the replacement was off. I visually checked it out on ebay (always a risky option, I know!) and its' worked!! Time for more Olympics now with a cup of tea.
7Back to top Go down   Center stands Empty Re: Center stands Wed Aug 08, 2012 1:22 am
BooG wrote:Did a bit of chopping and changing bushes/bolts and the like and its come good!.... Time for more Olympics now with a cup of tea.
As "sorted" as ten East Enders in a filing cabinet. Good work cheers
K75RTP - 1994
8Back to top Go down   Center stands Empty Re: Center stands Wed Aug 08, 2012 1:53 am
good solve boog ...
88KE wrote: a bit easier to get the bike onto but a bit harder to get it off!
88KE
looking into that 88 ...
hope to have a solution soon
9Back to top Go down   Center stands Empty Re: Center stands Thu Aug 09, 2012 1:43 pm
10Back to top Go down   Center stands Empty Re: Center stands Thu Jun 27, 2013 2:53 pm
t1slc
t1slc
Can anyone tell me if a 1996 K1100 center and side stand will fit on my 1991 K100rs?
How about an 1985 or 86 center stand to replace mine?
I'm having a hard time finding a used replacement in that 90-92 model year range...
11Back to top Go down   Center stands Empty Re: Center stands Thu Jun 27, 2013 4:00 pm
The K1100 will fit but the Early 8V Kstand wont fit.
12Back to top Go down   Center stands Empty Re: Center stands Fri Jun 28, 2013 12:29 am
The stands will swap around and actually fit....but they won't clear various and vital bits n bobs (like exhaust) on each of the bikes. In other words, 'some modification' will be required. Although there is still work to make them fit, it's easier to go forward than backward. My K100RS has a complete K1100RS stand set-up.
