1Back to top Go down   Wiring to the Coils... Empty Wiring to the Coils... Tue Jul 24, 2012 8:57 pm
twincarb
twincarb
I have just reconnected my coils, from the loom which connects to the controller, and then heads to the bottom of the coils... there are several wires... the ones that connect to the coils aren't a problem they are in the right locations...what i also have are 2 brown wires (earths) but I can't see where they connect or if they are redundant.
The Coils are earthed using a meaty ribbon cable which connects to earth (I have connected it to the bolt where it attaches to the frame...
Any suggestions?
Yamaha Thundercat
Wiring to the Coils... 169042Wiring to the Coils... 169034
2Back to top Go down   Wiring to the Coils... Empty Re: Wiring to the Coils... Tue Jul 24, 2012 11:41 pm
They connect to a couple of spade terminals which earth the core of the coils so that if the coils short to the core then you dont get frizzled if your leg touches the coil.
3Back to top Go down   Wiring to the Coils... Empty coil wiring Mon Jul 30, 2012 11:08 pm
paulang007
hi twin carb the ribbon cable is like an up grade earth because they used to have probs with the brown wires im looking into
getting duel spade attachments so i can use both sets of earth leads hope this helps paul007 Cool
4Back to top Go down   Wiring to the Coils... Empty Re: Wiring to the Coils... Tue Jul 31, 2012 5:36 am
twincarb
twincarb
That does make sense to me...
If you want to use the original as well... it may work snipping off the ends of the brown cables and reterminating them onto the ribbon cable.. solder etc
Yamaha Thundercat
