Go to page : Previous  1, 2, 3  Next
View previous topic View next topic Go down  Message [Page 2 of 3]
51Back to top Go down   Pannier key 044 - Page 2 Empty Re: Pannier key 044 Wed Aug 08, 2012 4:10 am
Really glad that key works. Lot to spend just to make your key ring heavier and more inconvenient to find the key you actually want.
On an unrelated note, just opened a bottle of wine. Had to look for the cork screw.
rossco
52Back to top Go down   Pannier key 044 - Page 2 Empty Re: Pannier key 044 Wed Aug 08, 2012 11:41 am
ainsjac wrote:Can I now join the KEY CLUB with all the others?
Welcome, you`re now a key member.......................
53Back to top Go down   Pannier key 044 - Page 2 Empty Re: Pannier key 044 Wed Aug 08, 2012 6:19 pm
Many thanks Inge.
54Back to top Go down   Pannier key 044 - Page 2 Empty Re: Pannier key 044 Wed Aug 29, 2012 12:44 am
55Back to top Go down   Pannier key 044 - Page 2 Empty Re: Pannier key 044 Wed Aug 29, 2012 6:56 am
kfilipow
kfilipow
I nominate RickG since he needs 4 keys, (but there is no #44).
56Back to top Go down   Pannier key 044 - Page 2 Empty Re: Pannier key 044 Wed Aug 29, 2012 7:04 am
I have bought a #49 but none of the others fit I need a 56, 65 & 44.
I might be able to work it so I can lock them on and secure 1 lock on each case while I look for the other keys.
I may borrow some and make my own.
57Back to top Go down   Pannier key 044 - Page 2 Empty Re: Pannier key 044 Wed Aug 29, 2012 6:28 pm
Rick, I have some brass and a 044.....and some time. I will have a go at making a couple of 044s. Found out that the key has to be that long in order to clear the rest of the lock casing.
Last time I tried this the little dremel wheel slipped and my left thumb became a softer option than the brass.
58Back to top Go down   Pannier key 044 - Page 2 Empty Re: Pannier key 044 Wed Aug 29, 2012 6:46 pm
ainsjac wrote:Last time I tried this the little dremel wheel slipped and my left thumb became a softer option than the brass.
Hmm......................keep in mind, the limit is 10 different locks.
59Back to top Go down   Pannier key 044 - Page 2 Empty Re: Pannier key 044 Wed Aug 29, 2012 7:25 pm
Well, I have tried again and every time I get it down to the right thickness and the groove is kind of straight I try it.
Most times it will bend or twist....do it three times and it breaks. I wonder if all brass is the same and whether heat from the cutting wheel is too hot and weakens the brass in the thinnest places. All you need is a little resistence and I fail.
Rick my 044 cost me about $12 Aus. landed here from the Boxer Man in the UK. Even when we don't get mail here every day it took exactly one week to get here.
There you have it from a member of the key club.
60Back to top Go down   Pannier key 044 - Page 2 Empty Re: Pannier key 044 Wed Aug 29, 2012 9:38 pm
Try 2 mm stainless.
Pannier key 044 - Page 2 Hpim0916
61Back to top Go down   Pannier key 044 - Page 2 Empty Re: Pannier key 044 Wed Aug 29, 2012 10:39 pm
How difficult is it to cut....is it harder, as in the opposite to soft?
62Back to top Go down   Pannier key 044 - Page 2 Empty Re: Pannier key 044 Wed Aug 29, 2012 10:51 pm
Harder to cut, but the advantage is that it isn`t so brittle as brass is.
63Back to top Go down   Pannier key 044 - Page 2 Empty Re: Pannier key 044 Thu Aug 30, 2012 10:20 am
i think we have some 1.6mm stainless around here (at work ) stan, ill try and send you some huh ?
better pm me your address
but to my way of thinking , if you have the key cut depths correct there should be little resistance of the lock going between open, closed (the action ) ...if your bending keys then this might be the reason why it is hard, try taking a little off the nose of the first bump or make a slight v in the height of that bump to clear the cam trigger
the width ...or is that depth of that nose section will be important also as it will fit inside the guides / cam mechanism ...if it were too wide it would bind
Pannier key 044 - Page 2 Key_cu10
64Back to top Go down   Pannier key 044 - Page 2 Empty Re: Pannier key 044 Wed Sep 05, 2012 2:07 am
zaubertuba
zaubertuba
Me too! Me too!
Anybody have an 064?
I didn't even knew my bags locked before I found this thread... Embarassed
1985 K100RS
65Back to top Go down   Pannier key 044 - Page 2 Empty Re: Pannier key 044 Wed Sep 05, 2012 3:56 am
No but I need a 56 and a 65. I got a message from the key seller and my 49 is on the way.
66Back to top Go down   Pannier key 044 - Page 2 Empty Re: Pannier key 044 Wed Sep 05, 2012 5:59 am
I got some stainless steel today from Charlie. I will "attempt" to fashion another 44 for you Rick. Can't help anyone else because my collection of these keys equals....one.
67Back to top Go down   Pannier key 044 - Page 2 Empty Re: Pannier key 044 Wed Sep 05, 2012 10:51 pm
Pannier key 044 - Page 2 P9060110
Not the prettiest piece of engineering....but it works! Rick, thanks to Charlie for the material I have a 044 key for you. You may shape the fat part to anything you desire. PM me on how you would like me to get it to you.
I think I will cut myself a spare...just in case.
68Back to top Go down   Pannier key 044 - Page 2 Empty Re: Pannier key 044 Wed Sep 05, 2012 11:02 pm
Looking at the jagged edges you should rephrase that as 'I think I will cut myself...just in case'
I have a 063 spare if anyone needs it. It is a copy (Eureka Locksmiths Dubbo circa 1810), but it works fine.
69Back to top Go down   Pannier key 044 - Page 2 Empty Re: Pannier key 044 Wed Sep 05, 2012 11:57 pm
Mine was cut at Ainsjac Locksmiths Dubbo , 2012. The jagged edges are a safety and security feature.....so no one will steal it from you because of the steel.
70Back to top Go down   Pannier key 044 - Page 2 Empty Re: Pannier key 044 Thu Sep 06, 2012 12:14 am
club_c
club_c
I also have a spare 063 key available, and I'm in the Northern Hemi. The problem with rossco's key is that if anyone from NA gets it, it's a reverse fit, since he's from 'the other side'.
1988 K100RS SE VIN 01477554
71Back to top Go down   Pannier key 044 - Page 2 Empty pannier keys Fri Sep 07, 2012 8:14 am
jandalboy
jandalboy
I've been searching for pannier key 059 and found five on e-bay USA .Searched for BMW key.Also found 040,042,043,046,050,053,057,061,062, 066,069.Hope it helps someone.
72Back to top Go down   Pannier key 044 - Page 2 Empty Re: Pannier key 044 Fri Sep 07, 2012 8:41 am
club_c wrote:I also have a spare 063 key available, and I'm in the Northern Hemi. The problem with rossco's key is that if anyone from NA gets it, it's a reverse fit, since he's from 'the other side'.
Don't you know anything you just use the other end first Pannier key 044 - Page 2 694830 :smoke:
73Back to top Go down   Pannier key 044 - Page 2 Empty Re: Pannier key 044 Fri Sep 07, 2012 10:11 am
good result stan ....hope it works well for you
74Back to top Go down   Pannier key 044 - Page 2 Empty Re: Pannier key 044 Fri Sep 07, 2012 11:40 am
I'm looking for a 049 key. The key that came with my K75 City Cases is a 046, which doesn't fit. Anyone out there know where I can get this? I've tried some of the Ebay links in this thread but none have 049.
Thanks.
75Back to top Go down   Pannier key 044 - Page 2 Empty Re: Pannier key 044 Fri Sep 07, 2012 12:31 pm
I didnt read all the threads but I was looking for keys for Krauser panniers and if you go to the website Michael Krauser will find them for you, very very helpful.
76Back to top Go down   Pannier key 044 - Page 2 Empty Re: Pannier key 044 Fri Sep 07, 2012 1:07 pm
robmack wrote:I'm looking for a 049 key. The key that came with my K75 City Cases is a 046.
It`s pictures of a 049 earlier in this thread, maybe the 046 could be modified?
77Back to top Go down   Pannier key 044 - Page 2 Empty Re: Pannier key 044 Fri Sep 07, 2012 6:32 pm
Thanks to Inge and Charlie for supplying an idea and the stainless steel for the key. Once you cut the blanks, it is easy to experiment with different nicks and filing until it works. Perhaps a closeup photo gallery is the way to go.
78Back to top Go down   Pannier key 044 - Page 2 Empty Re: Pannier key 044 Fri Sep 07, 2012 8:17 pm
robmack wrote:I'm looking for a 049 key. The key that came with my K75 City Cases is a 046, which doesn't fit. Anyone out there know where I can get this? I've tried some of the Ebay links in this thread but none have 049.
Thanks.
Rob I bought a 49 from a guy in Germany and its in the post so there is hope. I need to make a copy of it for myself and can make another or will scan both sides with some measurements and send ASAP. I still need a 56 and 65 if there are any out there.
79Back to top Go down   Pannier key 044 - Page 2 Empty Re: Pannier key 044 Fri Sep 07, 2012 8:21 pm
Rick G wrote:Rob I bought a 49 from a guy in Germany and its in the post so there is hope. I need to make a copy of it for myself and can make another or will scan both sides with some measurements and send ASAP. I still need a 56 and 65 if there are any out there.
Heh Rick, if you can make a copy for me at the same time you make one for yourself (when it arrives of course), that would be ideal. I'll pay for whatever it costs to duplicate and mail. PM me if you can help. Was the guy in Germany S.Meyer?
80Back to top Go down   Pannier key 044 - Page 2 Empty Re: Pannier key 044 Fri Sep 07, 2012 8:24 pm
I askes Stef Meyers and he didn't have any that I wanted. I will make one for you Rob and give you a yell when its ready.
81Back to top Go down   Pannier key 044 - Page 2 Empty Re: Pannier key 044 Fri Sep 07, 2012 8:25 pm
Inge K. wrote:... maybe the 046 could be modified?
I'll reference the photo and my 046 key to see how they match up. Do the teeth on the key matter at all? Throughout this discussion, it seems that only the position of the grooves is the discerning factor whether a key works or not.
82Back to top Go down   Pannier key 044 - Page 2 Empty Re: Pannier key 044 Fri Sep 07, 2012 8:29 pm
Just thinking (dangerous I know) about these keys If anybody out there in K land has these keys would you please either take a photo of both sides or scan both sides (prefer a scan as that gives scale) then send me the scanned docs to my email which is with each of my posts. that way I can put it togetherin one file and have Bert put it in the Downloads section for all to see.
83Back to top Go down   Pannier key 044 - Page 2 Empty Re: Pannier key 044 Fri Sep 07, 2012 11:29 pm
rob ...yes the profile is the main component of the key structure
the tooth section near the end of the key operates the latch ...so on that section it is really important to get it right
the main problem is getting blanks to make a dulication
i have visited several high end lockmiths and no luck yet
good luck
84Back to top Go down   Pannier key 044 - Page 2 Empty Re: Pannier key 044 Sat Sep 08, 2012 4:09 am
Well this is interesting.
I was just checking my keys again and the lock numbers. I have a 063 and 051.
So the key shown as 063 in my earlier post (page 1) will only open the 063 lock.
The key from Eureka Locksmiths Dubbo works perfect in BOTH locks.
Emails sent Rick with profile shots.
063
Pannier key 044 - Page 2 Dsc_1210
Pannier key 044 - Page 2 Dsc_1211
And the key that fits the 051 lock AND the 063 lock
Pannier key 044 - Page 2 Dsc_1213
Pannier key 044 - Page 2 Dsc_1214
85Back to top Go down   Pannier key 044 - Page 2 Empty Re: Pannier key 044 Sat Sep 08, 2012 4:17 am
Thanks Rossco. It's a wonder that beaten up one fits anything.
86Back to top Go down   Pannier key 044 - Page 2 Empty Re: Pannier key 044 Sat Sep 08, 2012 6:05 am
You know Rick, I don't think it is beaten up. Looks like it was hand cut with a chainsaw
87Back to top Go down   Pannier key 044 - Page 2 Empty 068 Thu Jul 11, 2013 2:59 pm
Ogri
Ogri
Does anyone have a spare 068 for sale? Or a scaled pic of both sides and I can make my own....?
Cheers :-)
http://www.globalmotorbikes.com/forums/index.php
88Back to top Go down   Pannier key 044 - Page 2 Empty Re: Pannier key Thu Jul 11, 2013 9:06 pm
KiltedK100
KiltedK100
Thank you so much! It wasn't until I was reading this post that I realized I have 6 locks on my bike that I knew nothing about. Now to find the key number...
~Ryan
1985 BMW K100RS
1984 Honda VT500C
89Back to top Go down   Pannier key 044 - Page 2 Empty Re: Pannier key 044 Mon Oct 14, 2013 6:37 pm
Comberjohn
Comberjohn
Hope that this helps those looking for pannier keys.
I have just ordered a new 048 key from James Sherlocks in the UK.
Not cheap at £14.40 but having a key must double the value of a set of panniers.
As they say, while stocks last. But I've got mine!
Life is not a rehearsal.
2010 VFR 1200F DCT
2010 R1200GS(gone)
1986 K100 Silver(gone)
2012 K1600GT(gone)
1984 K100 Red(gone)
90Back to top Go down   Pannier key 044 - Page 2 Empty Re: Pannier key 044 Mon Oct 21, 2013 3:05 am
westeng
westeng
Seeing your call for help prompted me to check my keys, not 044 but surely keys with this number have to be worth something
Pannier key 044 - Page 2 P1000912
91Back to top Go down   Pannier key 044 - Page 2 Empty Re: Pannier key 044 Sun Nov 03, 2013 3:47 pm
Englishkent
Englishkent
I'm after a 046 if anyone can help... Crossed fingers.
92Back to top Go down   Pannier key 044 - Page 2 Empty Re: Pannier key 044 Sun Nov 17, 2013 5:51 am
Englishkent
Englishkent
Englishkent wrote:I'm after a 046 if anyone can help... Crossed fingers.
Managed to find one on ebay.
1988 K100lt
93Back to top Go down   Pannier key 044 - Page 2 Empty Re: Pannier key 044 Wed Mar 12, 2014 7:01 am
Hi all, I missed all the keyman fun on this thread up until this week when Charlie directed me here while I was looking for an 057 key for BobW as I wan't on the forum back then.
My set of panniers has 056 & 057 and I have posted photos below. As those numbers were mentioned the photos may help someone.
I noted that the profile of these two numbers are a mirror image of each other.
Pannier key 044 - Page 2 Img_0916
Pannier key 044 - Page 2 Img_0917
94Back to top Go down   Pannier key 044 - Page 2 Empty Re: Pannier key 044 Tue Mar 25, 2014 7:09 pm
snowbeard
snowbeard
I just wanted to post on here that I'm looking for 057 for my 1987 LT panniers. as much for my own reference as anyone actually having a key for me! Wink
95Back to top Go down   Pannier key 044 - Page 2 Empty Re: Pannier key 044 Tue Mar 25, 2014 9:18 pm
Two possibilities to solve your search.
1) contact Larry "Stoner" Stonestreet of Stoner's Beemer Stash, Airhead Parts and Accessories
Larry Stonestreet
39628 Avenida Miguel Oeste
Murrieta, CA 82563
CA.STONER@YAHOO.COM
951-813-1704
I emailed him to find out if he had a 049 for me and he did.  You might luck out.
Also try James Sherlock
OR
2) get a local locksmith to manufacture a key.  That's what I did this week. I dropped off my bags, a copy of a 046 pannier key that I had and pictured of the 049 key I desired. One day later, the locksmith called to say my three keys were finished. Cost me $10 per key which I though was OK given the work he put into the milling and grinding.
Pannier key 044 - Page 2 DSC_0104
He used an Ilco 01122C blank and milled the based on the info he had as well as the lock.  He said that having the loch was better than having the 046 key although that helped to speed the process of shaping the tooth profile.
I've tested the keys and they work.
Question though.  I need only turn the lock mechanism on my City Cases barely 20 degrees in either direction to lock/unlock.  Is this correct?
96Back to top Go down   Pannier key 044 - Page 2 Empty Re: Pannier key 044 Tue Mar 25, 2014 10:03 pm
yes thats correct  rob
seems a small movement but you can defiantly feel the latch changing state
97Back to top Go down   Pannier key 044 - Page 2 Empty Re: Pannier key 044 Wed Mar 26, 2014 10:56 am
snowbeard
snowbeard
hmmm, looking at that 057 above and the 069 further above, they look nearly the same except for the grooves! I appreciate the photos, and I bet I can make a key for myself!
taking pictures with a ruler next to them is very helpful, thanks! (says he with no keys to offer the collective)
cheers!
Last edited by snowbeard on Wed Mar 26, 2014 11:07 am; edited 1 time in total (Reason for editing : realization that everyone already knew the grooves were the)
98Back to top Go down   Pannier key 044 - Page 2 Empty Re: Pannier key 044 Sat Apr 05, 2014 12:16 pm
snowbeard
snowbeard
well a big thanks to all of you who have posted pictures and added observations to this thread, I was able to make my 057 key from a piece of brass bar stock I saved from my Grandfather's stash 20 years ago. He worked for Cole Key company and also helped design the typical key cutting machine we all see everywhere. He had already used this piece of brass for making what looked like another key, but I only cut a small corner from the prize and look what it got me!!   Very Happy
I wanted to add that the important part of this key is the first cm, the rest in the pictures has nothing to do with the latch (it may have some part in other locks on the bike, but I haven't seen what) So when making a key the only part that matters is the end profile and the little notched bit at the very bottom.
It works a treat and I'm very happy to have locks on my bags again!! thanks to the collective intelligence! Pannier key 044 - Page 2 22936
Pannier key 044 - Page 2 Keyrule_zpsaf63f189
99Back to top Go down   Pannier key 044 - Page 2 Empty Re: Pannier key 044 Sat Apr 05, 2014 7:21 pm
You must have completed your key on a Sunday...hence a "holy" key.
100Back to top Go down   Pannier key 044 - Page 2 Empty Re: Pannier key 044 Sat Apr 05, 2014 9:34 pm
krambo
krambo
Thanks.
I have two 049 keys - could possibly get a couple cut locally.  Not sure what postage to Canada would cost from UK though.  Idea
"Aut viam inveniam aut faciam." Pannier key 044 - Page 2 Uk-bmw12
http://www.its-personal.net
101Back to top Go down   Pannier key 044 - Page 2 Empty Re: Pannier key 044 Sat Apr 05, 2014 10:31 pm
krambo wrote:I have two 049 keys - could possibly get a couple cut locally.  Not sure what postage to Canada would cost from UK though.  Idea
Thanks Krambo. I appreciate the offer. I had also inquired of a BMW used parts dearler in California and found that he ahd a copy of a 049 key. In the end, I had a local Toronto locksmith manufacture 3 copies of a 049 based on photographs. They work great, and that's the whole point after all; now I can lock my panniers and secure them to the bike.
View previous topic View next topic Back to top  Message [Page 2 of 3]
