Go to page : 1, 2, 3, 4
102 Thanks for getting back to me OG Wed Jul 11, 2012 8:10 pm
phoenixk2b
Man That's a good deal for a cover! Using the fast etch on the screws, did you then clear coat them? I have polished mine with a wire brush and fine sanding squares; since they all had different types and amounts of corrosion and rust they all look different. I did an earlier post asking about replacing them with stainless, I'm not sure I care for the bright finish but I could dull that down with the sanding squares. Sidecar paul sent me an answer that he'd used some stainless fasteners, but he didn't say he used them on that fuel rail/bracket. One of the things I worry about is that the screws I've found seem about 2mm shorter than the stock screws. At this point I can't see if they fasten anything on the "inside" of the bracket.
oops. I just looked at the question I asked you. Above, I'm asking about the screws in the bracket/rail that holds the throttle stop and fuel pressure regulator (on the inside of the bike) beneath the fuel body tubes.
BTW About your tankbag... I had a similar issue when I bought a tank bag for my Sabre 1100. It was very nice in that you could zip off the storage top and take it with you. The problem was that even if zipped off the base didn't have a hole for the gas cap. My solution isn't all that elegant, and I need to re-cut a cleaner piece, it's simply the squishy drawer liner available at walmart.
I just went and took a look on the blog I did for the Sabre. I never posted pics or that mod on the tank bag. I had to burn some holes for gps cable routing. My tank bag came with magnets, suction cups and straps. I simply did a quick pattern of the bag sitting on the tank, took the bag off and marked the hole for the gas cap. I cut everything out and then used the straps with snaps to tie into the "sticky base" I made. When I'm traveling, Now the home made squishy base stays on the tank, secured by the straps. When gas is needed I can just undo the forward snaps/clips and flip the bag back to fuel up. I can send or post pics on the blog if you'd like to see them (I haven't had luck getting pics up on my posts here)
Rick
K100 blog http://1985k100rsre-build.blogspot.com/: http://1985k100rsre-build.blogspot.com/
Rick
103 Re: 85 RS restoration (part #2) Thu Jul 12, 2012 3:51 pm
Oldgoat
Thanks for the info about the tank bag. I've not been out n about for any true distance rides yet so it's not been a concern, but it will be something to think about further down the road. I didn't paint the fasteners. Just a bit of lube and installed.
OG
OG
104 Re: 85 RS restoration (part #2) Thu Jul 12, 2012 3:52 pm
Oldgoat
Any one have experience with the 318i injectors?
http://www.ebay.com/itm/BMW-K1-K100-K100RS-K100RT-K100LT-318i-Fuel-Injectors-Best-Upgrade-4-Hole-Spray-/190702086548?pt=Motors_Car_Truck_Parts_Accessories&hash=item2c66bae994&vxp=mtr
Thanks,
OG
Thanks,
OG
105 Re: 85 RS restoration (part #2) Fri Jul 13, 2012 7:15 am
caferacer62
I have only had experience with them in a 318i OG i'm sorry. But i reckon they would be ok, ours are only about 125cc aren't they?
You could always run an adjustable fuel pressure regulator, thats what i'm fitting to mine as i have it in the shed with the supercharger kit i built for my son's 318i. Its got a guage on it as well so i can set the pressure as required.
Now if i could just fit the supercharger and intercooler.....hmmmm.
Bert 2.0
106 Re: 85 RS restoration (part #2) Fri Jul 13, 2012 8:21 pm
Oldgoat
Thanks CF62. I've been looking at those guys in Cali who do the turbos...but gawd wouldn't that be a slippery slop!!
OG
OG
109 Re: 85 RS restoration (part #2) Fri Jul 13, 2012 10:34 pm
yankeeone
Nice, I just put a new seal in timing cover but I fear I may have put it in a bit too far, find out in the am,
Bike looks great!
Bike looks great!
110 Re: 85 RS restoration (part #2) Fri Jul 13, 2012 10:38 pm
Oldgoat
Fingers crossed for you mate! What did you use to seal the cover?
OG
OG
111 She looks great OG Sat Jul 14, 2012 7:00 am
phoenixk2b
I just got my new coils yesterday. I'm hoping to do a test start by the end of the weekend
112 Re: 85 RS restoration (part #2) Sat Jul 14, 2012 5:11 pm
yankeeone
Hi, I used pematex product made for oil pans ect. black.seems to work.
Brian
Brian
115 Re: 85 RS restoration (part #2) Mon Sep 10, 2012 6:30 pm
Oldgoat
Things your gonna need for the job:
1) Spray adhesive - the 3M high-strength 90 is also good stuff and is readily available @ home depot for you state side guys.
2) 5/32 metal drill bit to drill out the rivets. Don't skimp on this one as the oem riverts are typical BMW quality and will eat cheap bits before you are finished with the job.
3) Door edge guard for covering the sharp edges on the seat pan and I've also used Gorilla tape with good success for the tighter angles, and for you more frugal guys I'm sure good ol duct tape would get the job done too.
4) 1/8" dia x 5/16 steel rivets are ideal, but 3/8" aluminum will also work if you can't find the 5/16 easily . Hand rivet tool.
5) Depending on the condition of your foam you may need some high density foam for replacement patches. I'm still doing a little research on this one and will report back on a couple of good sources...
6) Small clamps 4-6 should suffice with more being necessary if you want it all done in one whack.
7) Standard clothes dryer or a heat gun if putting bike stuff in the household appliances is strictly verboten!
OG
OG
116 Re: 85 RS restoration (part #2) Tue Sep 11, 2012 12:50 am
Halo
Watching closely OG this ones on my hit list for early next year. Looks like your going about it propper like as usual OG.
Halo
Halo
84 K100RS 0014803
93 FZR1000 EXUP
117 Re: 85 RS restoration (part #2) Tue Sep 11, 2012 4:02 am
walfish
OG -Going back to my years spent chair manufacture, we preheated the vinyl under spotlamps for approx. 10 - 15 mins, also fitted a 1/4" standard foam on top of the foam form, this seemed to add comfort(soft feel on the bum), the heated vinyl was then placed over the preglued seat, worked the heated vinyl to the shape and left to stand, heat gun only used on the corners and bends so as not to distort the shape of the foam.
Do not stretch the vinyl when placing on the foam, the preheat is to allow it to take the shape.
Hope this helps, it is time consuming.
88 K 100 0033026 (gone)
92 K 1100 LT 6455097 (gone)
118 Re: 85 RS restoration (part #2) Tue Sep 11, 2012 5:35 am
so good to see you back og ......i chose a vynal with a verry grippy pattern ....it worked well old mate ....nothing worse than sliding back into the hole that your behind doesnt like after a few hundred miles ...
good work ...keep going mate ...its nearly there !
(yeah i know it will never be finished ..but good to have a benchmark in place huh ?)
119 Re: 85 RS restoration (part #2) Tue Sep 11, 2012 12:03 pm
Oldgoat
Thanks guys! Yep, Halo as is my usual MO I've messed this one up more than once and I'm determined to get some decent results on this go around. Thanks for the expert counsel Ungaas! It echo's what I've been learning about upholstery and at this point I plan on getting a bunch of small clamps to fit the vinyl over the foam so it can cool and take the shape more properly before actually gluing it down and installing the rivets.
Also, for you guys stateside there is an excellent shop that does custom work and also will sell you material so you can go as stock or as wild as you wish.
http://www.mredsmoto.com/
Finally another link to get the good stuff in 1/4" foam Ungaas is talking about to go over the OEM foam.
http://www.jacobsupholstery.com/inc/sdetail/630
OG
OG
121 Re: 85 RS restoration (part #2) Thu Sep 13, 2012 6:51 pm
Halo
Gee OG not looking forward to this bit of the resto
Halo
Halo
84 K100RS 0014803
93 FZR1000 EXUP
122 Re: 85 RS restoration (part #2) Thu Sep 13, 2012 7:45 pm
Oldgoat
No worries Halo. I'm betting you guys who are not as ham-fisted as I should not have so many problems. Also, I'll post my final successful procedure in the hopes of giving you a head start on it!
OG
OG
124 Re: 85 RS restoration (part #2) Thu Sep 13, 2012 8:52 pm
Halo
Good man OG
84 K100RS 0014803
93 FZR1000 EXUP
125 Re: 85 RS restoration (part #2) Thu Sep 13, 2012 9:46 pm
Toto_jp
Nice job OG did start to wonder about creasing at front after the first photo but the second photo shows you eliminated the problem. When are you taking orders looks a better job than I could attain at the moment
Cheers Tony
Cheers Tony
126 Re: 85 RS restoration (part #2) Thu Sep 13, 2012 11:19 pm
Oldgoat
Thanks guys. I got my roomie to shoot a quick vid of the process on her phone so when I get it converted I will post.
OG
OG
127 Re: 85 RS restoration (part #2) Fri Sep 14, 2012 12:42 am
Oldgoat
Ok, guys this was shot quick & dirty with no edit so you'll have to forgive the small mistakes, but hopefully this will help some folks who are redoing their seats.
OG
OG
128 Re: 85 RS restoration (part #2) Fri Sep 14, 2012 1:06 am
Your video is great except for one thing.......I have been walking around with my head at 90 degrees to the left. If it was upside down, I would understand as it would have been made for Australians....down under.
At least I now know what an old goat sounds like. Keep up the great work...you do inspire us to keep going and trying new things.
1983 K100 basic vin 0003960 colour red GONE
129 Re: 85 RS restoration (part #2) Fri Sep 14, 2012 1:22 am
Great video.
Better move that one to the 'how to' section
And they are not the hands of an 'old goat'.
130 Re: 85 RS restoration (part #2) Fri Sep 14, 2012 2:18 am
Halo
You have led as astray for all this time your not a old goat at all, rossco is right ?. Well done
Halo
Halo
84 K100RS 0014803
93 FZR1000 EXUP
131 Re: 85 RS restoration (part #2) Fri Sep 14, 2012 2:22 am
club_c
Nicely done. I had ordered a new cover off of Ebay, but never could get it to lay down flat. Nobody said 'glue'. Ended up buying a pretty decent original seat and sold the other one. This looks like it should be fairly straightforward.
1988 K100RS SE VIN 01477554
132 Re: 85 RS restoration (part #2) Fri Sep 14, 2012 3:39 am
good work og ...
looks nice ...thanks for the tutorial ..
133 Re: 85 RS restoration (part #2) Fri Sep 14, 2012 5:58 am
See, I knew it was only a ten minute Job! (It sez so on you tube )
+1 move to How to section.
Thanks OG.
rossco wrote:Great video.
Thanks OG.
88....May contain nuts!
K75RTP - 1994
134 Re: 85 RS restoration (part #2) Fri Sep 14, 2012 2:45 pm
Oldgoat
Thanks guys. Yep, Clubbie I did the same thing getting that cover off of Fleabay last year and was very unsatisfied with the results too. Problem is that the vinyl is not of high enough quality to do the job right and I was ignorant about the finer points of putting it down correctly. Live and learn I guess...
OG
OG
135 Re: 85 RS restoration (part #2) Sat Sep 15, 2012 4:18 pm
brickrider
I'd planned to do this very job some time ago, and purchased the BMW OEM cover for a K1100RS seat. I lost my nerve and had a professional remake the seat. Now I have a cover I no longer need. $40.00US fob Boise, Idaho, USA and its yours.
136 Re: 85 RS restoration (part #2) Mon Sep 17, 2012 4:27 pm
Oldgoat
Ok, guys part II on the seat as promised. Fairly good results and I may end up doing a part III when I redo the solo seat this fall...
https://youtu.be/8_76gdO4wRc
OG
OG
137 Re: 85 RS restoration (part #2) Thu Sep 20, 2012 2:18 pm
Oldgoat
Question for you guys about front end alignmet: Has anyone used a tool to help insure the tubes are spot on? I was looking at something like this...
http://www.cycleworks.net/index.php?main_page=product_info&cPath=29_33_50&products_id=66
OG
OG
138 Re: 85 RS restoration (part #2) Thu Sep 20, 2012 3:48 pm
not sure about the tool og ...
the locals here ran me through a bouncing process of the front end to align the big through bolt (axle) and the height of the forks through the tripple clamps ...after wards it all lined up verry well .
i would imagine if the spacers were correct , it all should pull up nice and straight ?
139 Re: 85 RS restoration (part #2) Thu Sep 20, 2012 7:35 pm
Oldgoat wrote:Question for you guys about front end alignmet: Has anyone used a tool to help insure the tubes are spot on?
Ue this technique and DIY tools:
Fork alignment by Randy Glass. This is the best article on the subject.
Fork alignment testing tools.
Test for telescopic fork stiction.
140 Re: 85 RS restoration (part #2) Thu Sep 20, 2012 11:43 pm
Oldgoat
Perfect! Thanks so much for the great links Rob. I've been getting cranky with the front end still not being where it should be and its past time to get it sorted properly.
OG
OG
141 Re: 85 RS restoration (part #2) Sat Sep 22, 2012 5:47 pm
Oldgoat
Anyone have any experience with one of these?
http://www.beemerbalancers.com/standbalancer.php
Thanks,
OG
Thanks,
OG
142 Re: 85 RS restoration (part #2) Sat Sep 22, 2012 8:38 pm
I use that system of balancing my wheels and it is always good.
I use a shaft on 2 knife edges and it works well. I used one that was almost identical to that and it did it well.
144 Re: 85 RS restoration (part #2) Fri Apr 05, 2013 6:11 pm
Oldgoat
Ok, guys I'm finally getting around to putting together the solo seat so I went out to Mr. Ed's Moto and bought some supplies from the owner Don. His custom seat work is outstanding. Also a great guy who is willing to share his knowledge and he was very helpful.
The dual seat has been holding up fairly well so hopefully with what I've learned along the way the solo will be much less of a pain...we shall see!
OG
OG
145 Re: 85 RS restoration (part #2) Fri Apr 05, 2013 7:09 pm
Halo
Can't wait to see the new seat on OG looks great
84 K100RS 0014803
93 FZR1000 EXUP
146 Re: 85 RS restoration (part #2) Fri Apr 05, 2013 8:04 pm
good to see you still around og ...
yep also waiting to see the new mods mate ...cheers !
147 Re: 85 RS restoration (part #2) Fri Apr 05, 2013 8:42 pm
Oldgoat
Thanks guys...yep still kicking Chaz! I'm gonna need to chat with you on wheel swaps again soon I think. I rode a Michelin Anakee 3 on an Adventure bike and was very impressed with the on road performance and I've been seriously considering trying a 140/80/17 on a 3 inch k75 rear wheel I've got...
OG
OG
148 Re: 85 RS restoration (part #2) Fri Apr 05, 2013 9:10 pm
nice ...!!! sounds great og ...will look fantastic and lots of grip i suspect
149 Re: 85 RS restoration (part #2) Fri Apr 05, 2013 9:24 pm
Oldgoat
I found one where they did this except with the Avon tires.
The catch is that Michelin list the required rim width at 3.5" and the k75 is only 3", but I've talked to a couple of dealers and they don't think it would be a deal breaker. Of course could go down to the 130 which only requires the 3" rim , but I'd probably go with the 1100 rear at that point...
150 Re: 85 RS restoration (part #2) Fri Apr 05, 2013 9:29 pm
Oldgoat
Before I forget do any of you guys have wheel welding shops you can recommend that do rim extensions? Kosman Specialties here in the states was sold to some kids and has gone in the crapper.
151 Re: 85 RS restoration (part #2) Mon Apr 08, 2013 8:12 am
Glad you're back OG,
Similar topics
