1Back to top Go down   Rear Main Seal Replacement Empty Rear Main Seal Replacement Thu Jul 05, 2012 7:37 pm
docious
Hi Folks,
I have been scouring the forums to find more info about replacing the rear main seal on my 1985 K100RT and I need a little more help. I have read all of the great tips about removing the seal etc., but I was hoping someone could tell me which seals I should be replacing with part numbers or a link to a microfiche. I have some oil dripping out of the hole under the clutch housing and from what I gather it is likely the rear main seal. I have been looking a microfiches and have not been able to locate the part I need. I would love to just go to my local BMW shop, but after my last few interactions with the parts guys they don't really seem to know their stuff.
Sorry if I am being redundant, but I appreciate any advice you all can share.
Thanks,
Brandon
[img]Rear Main Seal Replacement Photo_10[/img]
2Back to top Go down   Rear Main Seal Replacement Empty Re: Rear Main Seal Replacement Thu Jul 05, 2012 8:15 pm
Good evening Doci!
The procedure and parts is similar as on the K75.
The description you find here.
One thing that would be different on your bike is the torque on the nut.
1. 140 Nm.
2. Back off.
3. 50 Nm.
4. Then another 50 degree turning angle.
The part # on the O-ring is superseeded by 11 21 1 460 467.
The part # for the seal is 11 11 7 666 186.
The mounting screws (x6) have a narrow head, and is rather soft
(one time use according to BMW) so it could be a good idea to order those to,
part # 21 21 1 454 417.
3Back to top Go down   Rear Main Seal Replacement Empty Re: Rear Main Seal Replacement Thu Jul 05, 2012 8:34 pm
First of all have a smell of the oil and determine if it is comming from the engine or gearbox and compare the smell by dipping something into the gearbox. It most likely is the engine mainseal.
The seal and O ring are available as aftermarket parts. You may prefer to use OEM.
As For a spare parts man, GITH from this forum is taking up a job with a dealer in Seattle and he does know his stuff (it may be stuff but he knows it) I can't remember which one now but he will be along soon to tell you
4Back to top Go down   Rear Main Seal Replacement Empty Re: Rear Main Seal Replacement Fri Jul 06, 2012 12:06 pm
docious
Thanks for the help! Much appreciated.
5Back to top Go down   Rear Main Seal Replacement Empty Re: Rear Main Seal Replacement Fri Jul 06, 2012 12:35 pm
docious
Inge,
Would you recommend that I order all the parts listed in the imbwr article?
11-21-1-460-456 19 mm o-ring Qty. 1
11-21-1-460-696 Pressure Ring Qty. 1
11-21-1-460-797 M20 Nut Qty. 1
21-21-1-242-377 Clutch washer Qty. 6
Thanks for your help!
-Brandon
Inge K. wrote:Good evening Doci!
1. 140 Nm.
2. Back off.
3. 50 Nm.
6Back to top Go down   Rear Main Seal Replacement Empty Re: Rear Main Seal Replacement Fri Jul 06, 2012 12:44 pm
Yes, but about the O-ring, read post #2 one more time.
I also have added part # for the seal and the screws.
7Back to top Go down   Rear Main Seal Replacement Empty Re: Rear Main Seal Replacement Fri Jul 06, 2012 12:56 pm
docious
That is what i thought, I just wanted to double check.
Inge K. wrote:Yes, but about the O-ring, read post #2 one more time.
paul.dickson_VA
paul.dickson_VA
Hello Docious - I was interested to find that you are working on virtually the same bike/leaks that I am getting into. I would love to stay connected with you as you progress, as I am doing the very same tear down and seal replacements. I look forward to learning from you, and sharing with you, all that will happen in the future seal replacements. Thanks.
Paul
9Back to top Go down   Rear Main Seal Replacement Empty Re: Rear Main Seal Replacement Fri Jul 13, 2012 7:31 pm
docious
I have made it to the seal. I will post pics in a thread later. We'll see how it goes Smile
