1 Possible valve problem? Fri Jul 13, 2012 2:10 am
paul.dickson_VA
While preparing to tear down my 85 K100RT and removing the exhaust, I noted that of the four exhaust pipes only front pipe (closest to the front wheel) has a bit of sheen/moist oil at the top of the pipe. All other pipes simply had dark carbon in the top of the pipes. I am thinking that this leans toward a valve problem where the wet area is in the first pipe. Any thoughts?
Thanks.
Paul
Thanks.
Paul
