ali2908
ali2908
I bought a second hand exhaust from an 1987 K100 RS for my 1985 RS but they are slightly different
original exhaust part no 18 12 1451 528
replacement 18 12 1454 918
The mounting bracket is about 25mm closer to the manifold, with the same 2 hole plate as the original, should I make an adaptor bracket, or does anyone have any other ideas. The side stand does not clear it either have I wasted my cash?
Ali
twincarb
twincarb
The easy option is to list it on ebay and provide the correct details of what it fits then hunt out the one you need, esp as not only a bracket needs making but an adjustment or a replacement stand would be needed....
Yamaha Thundercat
1985 K100 RS replacement exhaust not same 1690421985 K100 RS replacement exhaust not same 169034
All you should need is the late model rubber mounting. It bolts to the 2 holes in the footpeg plate and one on the muffler.
ali2908
ali2908
really confused now checked both the part numbers on the realOEM fiche and neither of the exhausts have the right part number. Is there anywhere I can search by part number without having to put the bike model number etc as well.
Ali
Agerbundsen
Agerbundsen
ali2908 wrote:really confused now checked both the part numbers on the realOEM fiche and neither of the exhausts have the right part number. Is there anywhere I can search by part number without having to put the bike model number etc as well.
Ali
I real Oem, put the part number in the box following PART NR APPLICATION SEARCH and you should get the data on the original application
ali2908
ali2908
That is what I tried no results
ReneZ
ReneZ
Something's wrong mate. Both the numbers you give are not being recognised by the system. Where did you find them?
Easiest is putting your bikes' VIN number in realoem.com and see what the part number for your bike should be, then search for that.
Rene
BMW K100 - 1985 (0030029) Scotland 1985 K100 RS replacement exhaust not same Rain
Agerbundsen
Agerbundsen
ali2908 wrote:That is what I tried no results
It probably means that the part numbers you quoted are no longer used or available. I did an estimated search and came up with the following:
Part 18122310397 (Muffler) was found on the following K589 vehicles:
K589 K 100 83 (0501,0511) N/A, , Europe (0501) : Exhaust system
K589 K 100 88 (0521) N/A, , Europe (0521) : Exhaust system
K589 K 100 LT 87 (0506,0516) N/A, , Europe (0506) : Exhaust system
K589 K 100 RS 83 (0502,0503,0513) N/A, , Europe (0503) : Exhaust system
K589 K 100 RS 83 (0502,0503,0513) N/A, , Europe (0502) : Exhaust system
K589 K 100 RT 84 (0504,0505,0514) N/A, , Europe (0505) : Exhaust system
K589 K 100 RT 84 (0504,0505,0514) N/A, , Europe (0504) : Exhaust system
Dunno if that is of any help?
ali2908
ali2908
These numbers are stamped on the exhausts
