1Back to top Go down   Dismantling the bevel box Empty Dismantling the bevel box Thu Jun 21, 2012 4:14 pm
Normally the final drive housing comes apart fairly easily with a few taps from a soft headed hammer on the caliper mounting lugs.
However, if you have one that is really stuck, then be aware that the bolt hole opposite the caliper lugs is tapped M10. A 10x1.5 mm bolt in this hole will gently jack the two parts of the casing apart, with a little help from your soft hammer on the lugs. (I cleaned the paint out of the thread to make it stand out on the photo)
Dismantling the bevel box Ssl10931
I can't see any other reason for this hole being tapped, but this method of parting the cases is never mentioned in the repair manuals.
2Back to top Go down   Dismantling the bevel box Empty Re: Dismantling the bevel box Fri Jun 22, 2012 4:52 am
great tip paul .....
thanks for the pic as well
3Back to top Go down   Dismantling the bevel box Empty Re: Dismantling the bevel box Fri Jun 22, 2012 10:46 am
In the words of Michael caine...."Not a lot of people know that!" Good tip Dismantling the bevel box 112350
Dismantling the bevel box Ir-log1188....May contain nuts!Dismantling the bevel box Ir-log11
K75RTP - 1994
