1Back to top Go down   Steering damper on K100RS 16v Empty Steering damper on K100RS 16v Thu Jun 14, 2012 5:58 pm
mr grumpy
mr grumpy
I really don't like this; it's like walking through treacle at low speed, so I'm inclined to unbolt it and bin it. Should I expect any adverse high-speed effect?
K100RS 16v
2Back to top Go down   Steering damper on K100RS 16v Empty Re: Steering damper on K100RS 16v Sat Jun 16, 2012 2:31 am
Agerbundsen
Agerbundsen
Are you sure it's the damper and not just the normal klutziness of the K100 RS at less than 10 mph??
I perceive my damper as non-restrictive and not interfering at slow speed. If it does anything at higher speeds is not easy to determine.
3Back to top Go down   Steering damper on K100RS 16v Empty Re: Steering damper on K100RS 16v Sat Jun 16, 2012 2:34 am
Absolutely agree with Agerbundsen I have no issues with the damper and don't find it a problem at all.
4Back to top Go down   Steering damper on K100RS 16v Empty Re: Steering damper on K100RS 16v Sat Jun 16, 2012 4:19 am
mr grumpy
mr grumpy
I guess it could be a case of "they all do that, sir", but I am surprised by how much heavier and unstable it feels than my RT, which for its size is a total pussy for the through the cones bit on CBT. I suppose the RS's larger tyre and different riding position are also factors; trial by experiment I think. Thank you both for your comments.
K100RS 16v
5Back to top Go down   Steering damper on K100RS 16v Empty Re: Steering damper on K100RS 16v Sat Jun 16, 2012 4:31 am
I have found that my K1100LT is a lot easier at low speed manuvering than a K1100RS I reckon it is just the narrower bars and seating position of leaning forward a bit more.
6Back to top Go down   Steering damper on K100RS 16v Empty Re: Steering damper on K100RS 16v Sat Jun 16, 2012 7:03 am
That is a very good point the wider bars would increase the leverage and the seating position too
7Back to top Go down   Steering damper on K100RS 16v Empty Re: Steering damper on K100RS 16v Sat Jun 16, 2012 7:06 am
Agerbundsen
Agerbundsen
K-BIKE wrote:That is a very good point the wider bars would increase the leverage and the seating position too
....and completely block the view through the mirrors too.......Embarassed
8Back to top Go down   Steering damper on K100RS 16v Empty Re: Steering damper on K100RS 16v Sat Jun 16, 2012 7:23 am
electric_monk
electric_monk
What tyre pressures are you running?
9Back to top Go down   Steering damper on K100RS 16v Empty Re: Steering damper on K100RS 16v Sat Jun 16, 2012 8:06 am
MT350Explorer
MT350Explorer
Hi Mr G
I've ridden my 4 valve K100RS with and without the damper and notice no difference in steering. Maybe trial and error as you say. Could be the damper is defective, it's easy enough to take off and put back back on. Alternatively could be something else like the guys suggest?
In the end I trusted the bike was given it by BMW for a (safety) reason so I left it on. This debate is subject of another post
Dave
1991 K100 RS 16 valve
10Back to top Go down   Steering damper on K100RS 16v Empty Re: Steering damper on K100RS 16v Mon Jun 18, 2012 6:01 pm
mr grumpy
mr grumpy
Tyre pressures are my personal default setting for low profile radials of 36 psi front, 42 rear, which is a little higher than the handbook figures. The first time I rode the bike it had stood for some time and the front tyre was down to 1.7 bar (about 25 psi) and it felt really terrible, so I guess it is particularly sensitive to front tyre pressure. I have to a great extent become familiar with the very noticeable "self-steer" tendency on low speed turns, which is not unlike my old airhead R100RS and before that a R75/6, so it may really just be a case of refamiliarisation and learning to live with it. I think I will still try it with the damper off, though, just to see if there are any adverse effects at high speed. Thanks for all the advice.
K100RS 16v
