1Back to top Go down   2004 k1200 motor Empty 2004 k1200 motor Mon Jun 18, 2012 8:37 pm
yankeeone
Hi, is it possible to use a 2004 k1200 gt motor in a 87 k100 rt?
2Back to top Go down   2004 k1200 motor Empty Re: 2004 k1200 motor Mon Jun 18, 2012 9:24 pm
With the Motronic control, wiring loom and all injection and air intake components, yes. It'll be a real project but it has been done before. The 'bell housing' from the original motor will have to be used unless you're going to swap in the six speed gearbox, swingarm and Paralever final drive arrangement from the K1200, and you may have to mix 'n' match parts of the clutch components, too. It would help to have two complete bikes with the K1200 the far less-desirable of the pair the one not to restore.
http://www.bmwmoa.org/features/engine_upgrade/BMWMOA_ON_engine_upgrade.pdf
Last edited by Guest in the House on Tue Jun 19, 2012 12:02 am; edited 1 time in total
3Back to top Go down   2004 k1200 motor Empty Re: 2004 k1200 motor Mon Jun 18, 2012 11:06 pm
yankeeone
Wow, that was the link, thanks, the wiring would be a bit too much of a challenge.
thanks
