1 Starter help Mon Jun 11, 2012 5:55 pm
mack8882
I am a new owner of a 1991 K100RS. I am having no response from the starter the last few days. I contacted the seller and he provided me with a receipt less than a year old for the battery. The symptoms I am dealing with and seeking advice for are:
- When the starter is pushed in, the engine doesn't even try to start. You can only hear a clicking noise.
- The left turn signal will not remain flashing when pushed in once. It only comes on when you hold it in.
- The right turn signal does the same except it signals for the left side as well
- The headlights do not come on at all when the key is turned to "on"
- The battery indicator (red light) is on when the key is turned to "on" but again the battery is less than a year old and I haven't accidentally left the keys in the "on" position for any extended amount of time
Any suggestions on the root of the issue would be much appreciated!
Thanks,
Craig M.
Thanks,
Craig M.
