1 Where would this cable go? Sat Jun 16 2012, 21:38
ianburgess
I bought a K100 last week, and before riding it, I decided to give it a good look over, and check the fluids etc.
Under the right side cover, I found a black wire with a round terminal attached, just floating around.
Following the cable across in front of the bottom of battery, it is connected to an earth point.
It does not prevent the bike from starting, but it obviously should go somewhere.
Any idea where I should be attaching it too?
I tried attaching a photo, but gave up after "hosting" the pickie a few times, but just in case it worked, this is the link.
Ian
Ian
