51 Re: 1986 K100RT ex police single seat Renno Tue Aug 14, 2012 10:35 am
starting to look pretty good rossco ....i like !
Go to page : 1, 2, 3, 4, 5
charlie99 wrote:starting to look pretty good rossco ....i like !
Its all in the lighting. Take the photo from a good distance, at night, with a flash. But thanks for the comments.Halo wrote:Rossco I am really impressed with the progress how did you get the bell housing & swing arm & final drive & the wheels so clean so fast they look really good
Halo
rossco wrote:..... Inge Bowl .
rossco wrote:..... The only part I took off was the spring mounted blocky pushy uppy thing to give a bit of movement to check the wear. Any thoughts? (knowing full well the answer )
rossco
Last edited by rossco on Fri Aug 24, 2012 2:33 am; edited 1 time in total (Reason for editing : added)
rossco wrote: RT inspired me to replace the fork oil using the Inge Bowl . No dramas.
Last edited by rossco on Sat Sep 15, 2012 1:46 pm; edited 1 time in total (Reason for editing : More info)
rossco wrote:Okay, if anyone wants me over the next week, just look for the guy hunting for a miracle.
That is what I will need to be ready in 5 weeks.
The bike is back together again. Had the gearbox and clutch off looking for the mysterious vibration.
It is the alternator.
Stuck the toolbox stethescope on it and it is rattling like a 2 year olds toy.
I will pull it off to check the rubber nuts are ok.
Failing that is there a rebuild kit for them or is it a new/ reconditioned one?
Lastly, I cannot get brake pressure on the rear brake. One seal was torn so got the kit, but I still can't get pressure. In 1st gear the motor is stronger than the brake.
Pads are ok, but not new so I will try new pads tomorrow.
Similar topics
