1 k100 85 stall on the road Mon May 07, 2012 1:05 pm
dewalque
Hello.
that's it, i'm in trouble here.
for the second time now i've been towed to my garage.
On the road, after one hour trip, the bike stop working. exactly like if you switch the kill switch at off.... once on the side of the road, the bike will not restart.(even no crank...) call the towing... go to my garage. The day after, on the morning, all is ok, it start and every thing is normal.
One week later, the sun is back, take the bike.... and voila, the same shit happen. It stop completely. If you try to start, only the pump is primed when i hit the start button, but the starter will not engage. The starter relay is receiving power when i push the start button (on the black-yellow wire) but the brown-red wire also is receiving power so the relay do not engage.... for shure i can jump the relay, and the starter will turn but no spark, no start. So, the igintion control module is not supling ground to my starter relay.... why.
I did read bertrand vogel(crazy frog) troubleshooting pages... and i'm stuck at the temp sensors..... it is writed that if the bike is in over heat situation, the bike wont start...ok so i did check ohm value of temp sensor at the fuel module, and it's in the spec.... now i'm searching for the temp sensing switch switch ,where is it? do you have an other idea....
Serge
Serge
