1Back to top Go down   fuel gauge plug  Empty fuel gauge plug Tue May 08, 2012 1:46 pm
lewy
lewy
working on fixing the fuel gauge i found the 4 pin roundish plug behind and below the rear of the fuel tank if i give it a wriggle the gauge works are all four wires for the gauge or something different and can it be replaced by something i can buy at an auto shop etc
2Back to top Go down   fuel gauge plug  Empty Re: fuel gauge plug Tue May 08, 2012 2:03 pm
There are a couple of posts about this subject on here, so a search will help.
Short answer, yes there are four-pin connectors (flat compared to the original round shape) that will do the job.
Is there a Jaycar shop up there? I think they sell what you're after.
3Back to top Go down   fuel gauge plug  Empty Re: fuel gauge plug Tue May 08, 2012 2:05 pm
g35corona
g35corona
Poor contact at this connector (and there will be others), is a common problem. Unless the connector is mechanically broken, the contact problem can be cured by treating with a product called Deoxit. There is a ton of information about it on this forum if you do a search for it. It will be a good investment.
Bob
;BMW;
ex:1986 K100 RT Vin #0091835
2012 R1200 GS
4Back to top Go down   fuel gauge plug  Empty Re: fuel gauge plug Tue May 08, 2012 2:15 pm
Good point g35.
Try DeoxIT first as g35 suggested. Available at Jaycar as well. At the risk of sounding like a broken record, use this stuff on every electrical connection on your bike (earths, bulbs, relays, switches, connectors etc).
5Back to top Go down   fuel gauge plug  Empty Re: fuel gauge plug Tue May 08, 2012 3:17 pm
after cleaning the socket part , you may find that squeezing the cylinder parts of the socket ,( so they have a smaller diameter ) will help enormously ....found my issue 30,000 k s ago and been good ever since .
6Back to top Go down   fuel gauge plug  Empty Re: fuel gauge plug Tue May 08, 2012 3:57 pm
lewy wrote: if i give it a wriggle the gauge works are all four wires for the gauge or something different
The most common reason to that owners finds out that they got a problem with this connector, is when the fuel pump stops to work.
White: warning lamp signal (ground) ...when empty.
Yellow: level gauge signal (variable ground).
Green/white: fuel pump power supply.
Brown: ground.
A useful? link.
7Back to top Go down   fuel gauge plug  Empty Re: fuel gauge plug Tue May 08, 2012 9:40 pm
lewy
lewy
Thanks all,exactly what i wanted I tried squeezing etc.cleaning with another contact cleaner,all i managed to do was stop the fuel pump from working thats why i asked what the four wires were for,guess its a trip to Jaycar for me.thanks again
8Back to top Go down   fuel gauge plug  Empty Re: fuel gauge plug Tue May 08, 2012 10:55 pm
Inge K. wrote:A useful link.
Nice job on the soldering but here is a tip....
When I do this type of job, even if I use heat shrink, I will cut all the wires at different lengths and stagger the solderings. This way, if the heat shrink get damaged I avoid the chances to get 2 connections touching each others. When all the wires are soldered together, I make kind of a harness with a bigger heat shrink (or electrical tape)
Here is an example on how I solder a double wire. (more wires, more staggering)
fuel gauge plug  Solde_10
Just my way of being different Very Happy
fuel gauge plug  Frog15fuel gauge plug  Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
9Back to top Go down   fuel gauge plug  Empty Re: fuel gauge plug Wed May 09, 2012 2:22 am
Good idea CF!
