1Back to top Go down   Exhaust Leak uncovered Empty Exhaust Leak uncovered Tue Mar 20, 2012 7:33 pm
Exhaust Leak uncovered Img_1114
I took the stupid rattling heat shield off yesterday, and found what may be the cause of my exhaust leakage.
Does anyone have any idea why these cuts would be on top of the pipe? I am going to plug them up anyway.
2Back to top Go down   Exhaust Leak uncovered Empty Re: Exhaust Leak uncovered Tue Mar 20, 2012 7:51 pm
Hi RT,
they are where one of the heat shield mounting brackets used to be welded.
Cheers,
3Back to top Go down   Exhaust Leak uncovered Empty Exhaust Leak uncovered Tue Mar 20, 2012 11:02 pm
Tks Sidecar Paul
at least an explanation I can live with. Now to find something that will plug them up, I've no access to a Stainless welder. Meantime I just can't afford to stop anywhere in case I go to sleep.
4Back to top Go down   Exhaust Leak uncovered Empty Re: Exhaust Leak uncovered Wed Mar 21, 2012 4:06 am
Lazyboy
Lazyboy
A quick fix would be a product called Pratley Putty Steel . It will seal the two small holes but wont stop the rattle ! I dont know if Pratley products are available in Aus.?
1984 BMW K100RT
Bikes Name: Lazyboy
5Back to top Go down   Exhaust Leak uncovered Empty Re: Exhaust Leak uncovered Wed Mar 21, 2012 4:19 am
col
col
rt is there exhaust shop close to home they should be able to weld it up for you
1991 k100lt "the enterprise"
6Back to top Go down   Exhaust Leak uncovered Empty Re: Exhaust Leak uncovered Wed Mar 21, 2012 8:16 am
g35corona
g35corona
I went to a custom exhaust shop nearby. They were easily able to fill similar holes and cracks with weld material.
Bob
;BMW;
ex:1986 K100 RT Vin #0091835
2012 R1200 GS
7Back to top Go down   Exhaust Leak uncovered Empty Re: Exhaust Leak uncovered Fri Apr 13, 2012 10:08 am
Finally_A_K
Finally_A_K
I did a temorary fix with a dab of high-temperature silicone.
It held for a looong time.
Rick
8Back to top Go down   Exhaust Leak uncovered Empty Re: Exhaust Leak uncovered Fri Apr 13, 2012 5:28 pm
I would personally build a stainless steel bracket for the heat shield.
After that you have 2 solutions:
You have the bracket welded on the exhaust or you drill 2 small holes in the exhaust and you screw the bracket over the 2 gaps. If you use stainless steel screws, they should last for at least 10 years.
Exhaust Leak uncovered Bracke10
Exhaust Leak uncovered Frog15Exhaust Leak uncovered Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
