2 Re: Exhaust Leak uncovered Tue Mar 20, 2012 7:51 pm
Hi RT,
they are where one of the heat shield mounting brackets used to be welded.
Cheers,
Cheers,
3 Exhaust Leak uncovered Tue Mar 20, 2012 11:02 pm
Tks Sidecar Paul
at least an explanation I can live with. Now to find something that will plug them up, I've no access to a Stainless welder. Meantime I just can't afford to stop anywhere in case I go to sleep.
4 Re: Exhaust Leak uncovered Wed Mar 21, 2012 4:06 am
Lazyboy
A quick fix would be a product called Pratley Putty Steel . It will seal the two small holes but wont stop the rattle ! I dont know if Pratley products are available in Aus.?
1984 BMW K100RT
Bikes Name: Lazyboy
5 Re: Exhaust Leak uncovered Wed Mar 21, 2012 4:19 am
col
rt is there exhaust shop close to home they should be able to weld it up for you
1991 k100lt "the enterprise"
6 Re: Exhaust Leak uncovered Wed Mar 21, 2012 8:16 am
g35corona
I went to a custom exhaust shop nearby. They were easily able to fill similar holes and cracks with weld material.
Bob
ex:1986 K100 RT Vin #0091835
2012 R1200 GS
7 Re: Exhaust Leak uncovered Fri Apr 13, 2012 10:08 am
Finally_A_K
I did a temorary fix with a dab of high-temperature silicone.
It held for a looong time.
Rick
Rick
8 Re: Exhaust Leak uncovered Fri Apr 13, 2012 5:28 pm
I would personally build a stainless steel bracket for the heat shield.
After that you have 2 solutions:
You have the bracket welded on the exhaust or you drill 2 small holes in the exhaust and you screw the bracket over the 2 gaps. If you use stainless steel screws, they should last for at least 10 years.
1986 k75, 1985 K100rt, |
K100-forum.com » Technical, repair and troubleshooting » Engine and transmission » Exhaust Leak uncovered
Similar topics
