MT350Explorer
MT350Explorer
Hi Guys
As the title says - is it or isn't it please?
Also:
Is the screw at the top marked S/H to adjust ride quality? I can't see it would do much?
Is the shocker upside down? Not as stupid a question as it seems; I saw a picture I can't now find suggesting it should be the other way up.
Thanks Very Happy
Dave
Is this a standard 16 valve shock absorber? Shocke10
Tony Kirov
Tony Kirov
Here is mine one
Is this a standard 16 valve shock absorber? Imag0076_63e50_27691930
When I bought the the bike, mine was also placed upside down
Is this a standard 16 valve shock absorber? 2854237993 BMW K100RS 4-VALVE (89V1) VIN#0205126 08/1991 ECE Is this a standard 16 valve shock absorber? 2854237993
MT350Explorer
MT350Explorer
Nice one Tony, thanks!
Like your bike, looks good in that colour
Dave
Standard shockie, correct mounted, adjusting screw is for rebound damping.
Agerbundsen
Agerbundsen
Inge K. wrote:Standard shockie, correct mounted, adjusting screw is for rebound damping.
So "S" is for softer and "H" is for harder?
mike d
[/quote]So "S" is for softer and "H" is for harder?[quote]
Sure is.
Mike
MT350Explorer
MT350Explorer
Hi Guys,
Well I found the origin of my confusion in the original handbook. It seems to confirm that the shock on my bike is upside down!
The handbook is for the K1 and K100RS 16 valve. It seems you adjust the K1 at the bottom and the K100 at the top
Is this a standard 16 valve shock absorber? Shock310
This is repeated in the diagram below
K1 above; K100RS below
Is this a standard 16 valve shock absorber? Shock410
So I suppose it must be right - baffling though?! Is this a standard 16 valve shock absorber? 8157
Best
Dave
Tony Kirov
Tony Kirov
May be on K1 is just mounted upside down to easy access, I'm not so sure... Question
I mentioned that shock absorber is changed in August 1991 /exact month of my bike birth day /
Any ideas from someone with more experience?
Actually is it matter how it is mounted?
Actually Tony, I think you are probably right with the K1 needing access to the adjuster; but being mounted as Dave's, with the adjustment at the top, does reduce the 'unsprung weight' so theoretically, that should be the better option.
K1 got a different part# than the two to fit the RS.
As TK mention it was a change in 08/91, when it was changed to Showa.
The later one is similar to the one fitted on the K11, which is the same as shown in the pictures (the earlier model didn`t have any adjustement for the damping).
