MT350Explorer
MT350Explorer
Hi Guys,
There seemed to be more green light on the insrument pod on the right than the left side so I removed the instrument pod and put TWO new green bulbs in and there's no improvement, still more green light on the right. Before I take the pod off again is this just the way it is or are there more than 2 green bulbs? I can't find out from either Haynes or Clymer. With the benfit of hinsight I should have looked when I was in there are tested the new bulbs were working - but hey ho. Very Happy
Dave
There are 2 on each sides. They are the ones mark +/-. The middle one is to light the clock.
The +/- are the polarity if you want to install LEDs
Instrument panel lights - how many green bulbs K100_c11
Instrument panel lights - how many green bulbs Frog15Instrument panel lights - how many green bulbs Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
MT350Explorer
MT350Explorer
That's brilliant, thank you Bert very much. I'm gonna stick with OEM for the time being as I actually like the level of light. Not sure why I assumed there were only two but there you go... Shocked
Best
Dave
MT350Explorer
MT350Explorer
Been away with work a while but back now and had a go at this again. Found that three of the green bulb contacts had one side of the printed circuit folded back under itself so there was no current to the bulb holder or bulb! Unfolded them and now all seems to be fine.Also found one of the green bulbs was actually a clear bulb painted with green paint so that had to go as well. Struck me again how well put togwether these bikes are and easy to work on - everything unbolts or unscrews. Small things make me happy Very Happy
All the best
Dave
komandoalicante
komandoalicante
Espectacular es el resultado de cambiar las lamparas del cuadro por una que compre de Dealextreme gracias a JANSOLO
Este es el cuadro antes de empezar
Instrument panel lights - how many green bulbs Cimg3166r
Estas las lamparas, la original con su casquillo y la nueva sin el
Instrument panel lights - how many green bulbs Cimg3176
Con el casquillo o porta lamparas quitado
Instrument panel lights - how many green bulbs Cimg3177
Y con el porta lamparas en la nueva
Instrument panel lights - how many green bulbs Cimg3180f
Estas son las cuatro de la iluminación
Instrument panel lights - how many green bulbs Cimg3181t
Y estas las del reloj y la del chequeo
Instrument panel lights - how many green bulbs Cimg3184
Y el resultado final
Instrument panel lights - how many green bulbs Cimg3187
¿Que opinais?
Mas información
Instrument panel lights - how many green bulbs Cimg3415
Instrument panel lights - how many green bulbs Cimg3419t
Lo primero, las fotos estan tomadas completamente a oscuras.
Y aunque no lo parezca, ya somos varios en coincidir que la luz procedente del cuadro no molesta a la conducción, teniendo una lectura clara y rápida.
Por otro lado, menos comprobado que en las lamparas que utilizamos, el conductor mas corto era el positivo, para eso desplegamos los conductores como podréis ver en la siguiente foto. (Ojo los conductores salen cada uno por un lado)
Instrument panel lights - how many green bulbs Cimg3416p
y tambien marcamos donde estan los positivos y negativos para montar en el cuadro.
Instrument panel lights - how many green bulbs Cimg34181
Si os fijáis pusimos un poco de typex en los portalámparas para diferenciar los polos + y -
y por último estos son los led que montaba Juanjo,(de un diodo) y los nuevos, son de cinco.
Instrument panel lights - how many green bulbs Cimg3417
SAK3 and komandoalicante is the same person
In March we made a International meeting  KEDADA ALICANTE of BMW motorcycle K in  Spain.
The last meeeting  March 2020
https://youtu.be/hfqxlGeEVsY
https://picasaweb.google.com/100417997445250027277
captaink
captaink
Excelente, agradable y claro, ¿cuánto tiempo se necesita para cambiar. Shocked
1989 k 100rs
komandoalicante
komandoalicante
40 minutes in my K 75 S and 1 hour on my K 1100LT
MT350Explorer
MT350Explorer
Sí, realmente bueno. Como el verde yo, pero estas son muy brillantes y claros de acuerdo
Best regards
Dave
