1Back to top Go down   idle switch Empty idle switch Sat Mar 31, 2012 2:09 pm
lesso
lesso
the idle switch is faulty. i followed the help on this site and when i unplug the switch it starts. i need to replace it. can anyone help i,m a complete novice and understand i have to remove tank. any help will be appriecated. i have k100rt 1987 model
thanks lesso
2Back to top Go down   idle switch Empty Re: idle switch Sat Mar 31, 2012 2:25 pm
lesso wrote:the idle switch is faulty. i followed the help on this site and when i unplug the switch it starts. i need to replace it. can anyone help i,m a complete novice and understand i have to remove tank. any help will be appriecated. i have k100rt 1987 model
thanks lesso
You can ride without the switch plugged in. The only draw back is that your engine could backfire when you decelerate and you may lose a bit of engine brake.
Few riders on this site have permanently disconnected this switch.
You have to remove the part of the fairing to remove the tank.
Check this
Bert
idle switch Frog15idle switch Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
3Back to top Go down   idle switch Empty thanks Sat Mar 31, 2012 2:31 pm
lesso
lesso
your post re this subject was brill. it helped a complete novice to understand the principles of the set up. hope you can help further when the situations arise
lesso
4Back to top Go down   idle switch Empty Re: idle switch Sat Mar 31, 2012 2:34 pm
Maybe.... Being a cyber mechanic is not always easy.
CF
5Back to top Go down   idle switch Empty Re: idle switch Sat Mar 31, 2012 7:40 pm
AFAIK it shouldn`t be necessary to remove the tank, to change the throttle position switch?
6Back to top Go down   idle switch Empty Re: idle switch Sat Mar 31, 2012 8:13 pm
true words there inge ....just remove the coils cover for easier access of the tps at the end of the throttle bodies ? and possibly the knee guards ?
7Back to top Go down   idle switch Empty Re: idle switch Sat Mar 31, 2012 9:07 pm
charlie99 wrote:true words there inge ....just remove the coils cover for easier access of the tps at the end of the throttle bodies ? and possibly the knee guards ?
You guys rocks....
Time for me to retire idle switch 652573
This is true that the switch has the plug with the &%%$#@! retaining wire on it.
8Back to top Go down   idle switch Empty Re: idle switch Sat Mar 31, 2012 9:35 pm
Crazy Frog wrote:This is true that the switch has the plug with the &%%$#@! retaining wire on it.
Push on the center of the wire, and the ends should open above the locking tabs.
(If it isn`t cooperative, the magic words &%%$#@!.... very often helps).
9Back to top Go down   idle switch Empty Re: idle switch Sat Mar 31, 2012 9:44 pm
And dont forget the chicken bone dance
10Back to top Go down   idle switch Empty Re: idle switch Sat Mar 31, 2012 10:00 pm
oh no!!!
dont even think about it bert ......please !!!
11Back to top Go down   idle switch Empty Re: idle switch Sun Apr 01, 2012 10:48 am
ReneZ
ReneZ
BTW with an angled screwdriver you don't need to dismantle anything
Something like this 👅
Rene
BMW K100 - 1985 (0030029) Scotland idle switch Rain
