1Back to top Go down   IGNITION LEADS Empty IGNITION LEADS Wed Mar 28, 2012 4:18 am
RSMITH
RSMITH
Hi All,
is it possible to seperate the HT Leads from the suppressors and replace the wire part?
i have one that is burnt through and happen to have a roll of brand new HT Lead wire.
thanks
2Back to top Go down   IGNITION LEADS Empty Re: IGNITION LEADS Wed Mar 28, 2012 5:30 am
All I ever do to fix them is buy the blue silicone leads fron an auto store and put resistive plugs in.
You can buy a new lead just about anywhere then if you need one.
3Back to top Go down   IGNITION LEADS Empty Re: IGNITION LEADS Wed Mar 28, 2012 5:39 am
RSMITH
RSMITH
so they can come apart without too much fuss? so it means I can re-use the suppressor and coil cap, and i then will be able to change the wire part only?
4Back to top Go down   IGNITION LEADS Empty Re: IGNITION LEADS Wed Mar 28, 2012 6:53 am
RSMITH wrote:so they can come apart without too much fuss? so it means I can re-use the suppressor and coil cap, and i then will be able to change the wire part only?
I was a bit ambiguous there. I use the blue silicon leads to replace the whole lot caps wire the lot. as the leads are not then resistive (5000 ohms) I use a resistive plug like NGK DR7EA instead of the standard NGK D7EA
5Back to top Go down   IGNITION LEADS Empty Re: IGNITION LEADS Wed Mar 28, 2012 7:03 am
RSMITH
RSMITH
ok - damm I was hoping that i could get away with just being able to change the wire itself.
thanks
