Albyalbatross1
Albyalbatross1
Today after reading about other peoples LED upgrades for brake lights, i installed some of my own. I picked up a couple of RED factory mounted submersible strips. A little exy but easy to use.
Brake Lights..An Easy Boost to Brightness Resize63
Pulled the rear tail light lens and wired them together, Mounted a strip each side of the brake light housing. They were a nice fit.
Brake Lights..An Easy Boost to Brightness Mounte10
tapped into the brake light power and earth..now i have a nice bright brake light that stands out when sitting in the UTE. had to get a drivers view on how they looked.
Brake Lights..An Easy Boost to Brightness Resize64
Just to show how bright the front led park lights are..
Brake Lights..An Easy Boost to Brightness Resize65
boristhebike
boristhebike
Neat work. Simple and functional.
KISS (keep it simple stupid) at its best. :pirat:
GB777
GB777
Great work
Gary
'94 K1100RS Mystic Red
•Dyno Tuned to deliver 115 bhp. •Audiovox CCS-100 Vacuum Cruise Control. •Fuel Plus Version 3.1 Trip Computer. •R1200c Final Drive Gears (32/13 or 2.54). •Ohlins rear shocky. •K100 complete Aluminium Radiator fitted. •Davies Craig Thermo Switch fitted to Cooling Fan with manual over-ride. •Fuel Cap drilled and tapped to provide mounting points for accessories, including mini Tank Bag & Apple CarPlay Screen •HID Hi-Lo Headlight and every other incandescent bulb on bike replaced with LED's. •Bulb monitoring warning light no longer needed so it's now used to indicate when Side Stand is down. •LED (Halo) Front Park Light (BMW Car style).
nice one alby ....verrily cool..
congrats mate ...
hey btw ...do i see night illumination inside the fairing ...?
They're good bright ones Alby. I see you've used the hot glue gun to mount them. Mine (inside the headlight has vibrated loose after only 100k's, moslty on bumpy back roads. I gonna restick them with something stronger.
PS what's the black part in the first photo?
Brake Lights..An Easy Boost to Brightness Ir-log1188....May contain nuts!Brake Lights..An Easy Boost to Brightness Ir-log11
K75RTP - 1994
88KE wrote:PS what's the black part in the first photo?
Seems like a "monkey nut", rubber damper used at the alternator coupling. (3 of them is needed).
Albyalbatross1
Albyalbatross1
Yes..Its just for scale.
Hot glue on 120 grit surface prep has worked well for me on other projects..being plastic and polythene, sikaflex will make the joint, but not so cheap for small job. I used small cable ties for the park lights.
I am also toying with some you "WILL SEE ME" in the corner of your eyes as you pull out without looking.
Last edited by Albyalbatross1 on Sun May 06, 2012 1:32 pm; edited 1 time in total (Reason for editing : .)
This is not a bad idea.
I don't want my bike to look like a Xmas tree, but a couple of LEDs well placed could be a great security feature.
Good work.
CF
Brake Lights..An Easy Boost to Brightness Frog15Brake Lights..An Easy Boost to Brightness Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
Albyalbatross1
Albyalbatross1
[quote="Crazy Frog"]
CF
The LED appear to be so bright due to the 15 sec exposure. (full moon). This picture gives you a much better idea of how it looks. Only a five second exposure. The air exghaust vents appear to glow. LEDs are mounted all the way forward near the radiator.
Brake Lights..An Easy Boost to Brightness Resize66
The idea is that people will notice something not is not NORMAL before commonly seen items. (and it kinda looks cool on the move at night) Cool
I know the brightness of the new LEDs. I have 24 of them in my parking light, and was not able to take a good picture of it. Remember the video that I posted around Christmas Very Happy
I have a Philips ultra white H4 bulb in my headlight, and it looks yellow in comparison of the LED parking light.
oh ! now i understand the reason for the light blocking at the fairing alby ...giggle .. shes a beudy mate ..
