C_Mick
C_Mick
I can't take credit for this idea - I saw it in use somewhere and thought it worth copying:
1. Trim a large alligator clip with a hacksaw...
2. Attach a good spark plug with cable ties...
DIY Spark Tester (a post for fellow 'Electrical Newbies') K75S-spark-tester
3. Test for a spark.
DIY Spark Tester (a post for fellow 'Electrical Newbies') K75S-spark-tester-in-use
This will tell you if the coils / HT leads are delivering sparks to the plugs. It won't tell you anything about the condition of the plugs in the cylinders. To find that out it's necessary to remove the plugs and inspect / test them individually.
Chris
Two wheels good...Four wheels bad...
Excellent idea.
That's a useful one! Think I'll make one of those myself.
good practical idea chris ...
GB777
GB777
Wow... what a simple and practical idea!
Gary
'94 K1100RS Mystic Red
•Dyno Tuned to deliver 115 bhp. •Audiovox CCS-100 Vacuum Cruise Control. •Fuel Plus Version 3.1 Trip Computer. •R1200c Final Drive Gears (32/13 or 2.54). •Ohlins rear shocky. •K100 complete Aluminium Radiator fitted. •Davies Craig Thermo Switch fitted to Cooling Fan with manual over-ride. •Fuel Cap drilled and tapped to provide mounting points for accessories, including mini Tank Bag & Apple CarPlay Screen •HID Hi-Lo Headlight and every other incandescent bulb on bike replaced with LED's. •Bulb monitoring warning light no longer needed so it's now used to indicate when Side Stand is down. •LED (Halo) Front Park Light (BMW Car style).
