1 Help indicators etc. Wed Feb 15, 2012 3:16 am
Ajays
When I got it back on the road, the RH indicator was not working....no power to the socket. (loose wire in housing I suspect) Then it was laid up again for 6 weeks while I sourced a less expensive battery which I found. Back on the road but indicators not working at all (Fuse OK and I cleaned all fuse connectors) and weeks later, the right indicator comes on when you press left button but does not stay on unless you hold the button down. All indicators come on when rH button is held down.
I don't believe its the new battery, as the Amp/hr rating was slightly less than the original. 18 i/o 20, if I remember correctly.
I suspect a bad connection to the indicator relay and will check that out. Any thoughts? Maybe a find on the Forum could pinpoint the cause.
This is from an old associate in South Africa and he has asked for a few pointers.
Any suggestions?
His email address is fijardine@gmail.com any answers here I will pass on.
Come on you Sparks experts.
Ajays
Any suggestions?
Ajays
