Steve75
Steve75
Hi Guys. I'm brand new to this forum stuff and I'm also brand new to bikes but I came across my k100rs for a price that I couldn't pass up. So now it's time for work. It hasn't been started for about 6 years so where do I start??? I would like to get it going before I restore it and I have restored a few cars before so I'm not to bad on the tools. Any suggestions with what I should do to attempt to start it after soooo long would be great.
Steve
Change all fluids...oil, oil filter, forks, gearbox, final drive, air filter, brake fluid etc.
Dump the existing fuel in the tank, change the fuel filter and while you're there, check the condition of the fuel lines. If they need replacing, use SAE30R10 type fuel lines (this type can be immersed in fuel). Check the fuel pump...it has a black rubber "vibration dampner" to help hold it place in the tank. Sometimes that black rubber can turn into a thick black glob. Especially so if it has been sitting in any fuel that has ethenol. Check the other fuel lines on the bike. Don't forget to use hose that is suitable for fuel injection.
Check/clean your injectors to see how they're performing.
Spark plugs...change them.
Make sure the battery is fully charged when trying to start it, otherwise there is a chance that the starter relay can weld its contacts together...and it'll keep on turning the motor over until you disconnect the battery!
Apply DeoxIT to every electrical connection/bulb/socket/switch on the bike. No, I do not have shares in the Company.
That's the main ones, no doubt the "collective" will chime in with more.
Fix it, ride it.
People will think you are a nut case because of the stupid grin on your face.
Oh yeah, welcome to the Forum!
Oldgoat
Oldgoat
Welcome on board Steve. Some of our most colorful members are down your way so you're in great company. Excellent shot of your bike!
OG
beanoldboy
beanoldboy
welcome steve75 . have fun mate.
http://www.airware.com.au
caferacer62
caferacer62
Welcome to the forum Steve, i think Blakey has covered most need to stuff.
The only other thing i would suggest is the spline lube on the drive shaft(you will find plenty of info for it on here). You could also do the splines on the clutch and the clutch contact areas that require lube, if you want to pull the gearbox out.
I hope you dont encounter the same problems i did, mine had also been sitting(not as long though) and some of my seals started leaking. But you probably wont find out until you start riding it. Rolling Eyes
Good luck with it all and enjoy.
Bert 2.0
G'day from Steve, NSW Australia, New member 170874
Welcome to the forum Steve. Just about all has been covered. Don't try to start it before the fuel sys makeover it may get some black goo in the pump from the remainders of the vibration damper. If you intend doing a restoration then things like the spline lube would not be neccessary but if you intend a rolling resto then all is required before riding.
For Aussie members old and new and young we have a get together on May 11, 12 & 13th hope you plan to come.
Signed the resident K Freak
Last edited by K Freak on Tue Jan 31, 2012 7:55 pm; edited 1 time in total (Reason for editing : typo)
Good point about the spline lube Bert 2.0.
Another thing Steve, if you're buying parts, have a look at Moto-bins or Motorworks (sp?) and Sherlocks in the UK. Check their sites for pricing and compare it to Munich Motorcycles in Perth, WA.
Google is your friend!
The cost of parts can be cheaper to buy and send to Australia that it is from Munich Motorcycles just for the part alone.
Microfiche that shows all the parts for your bike is available from Max BMW Motorcycles in the USA. Google them as well.
Ghost who rides
Ghost who rides
A "flushing " oil change using diesel engine oil would be good first up, consensis here is to do this is anyway every few changes . This is to remove gunk built up especially in the starter sprag clutch which is known to give trouble.
Cheers G
Albyalbatross1
Albyalbatross1
hello Steve75. Read on and learn.
Toto_jp
Welcome to the forum mate. Remember to park it on its side stand every time you stop whilst out to let the old girl "mark" her territory Smile
Welcome to the forum. Only lunatics join.
hiya steve ....i guess blakey has done a good compendium of the things that we all have experienced in some way or another .
good to see you here...and lets hope we have another "k" bike saved from the wreckers..... they really are a great bike to ride and hope to see you grinning like the rest of us soon .
col
col
welcome steve
the enterprise sat for 10 years did what blakey said and she started up ( had to change fuel pressure regulator as well )and hasnt missed a beat yet
1991 k100lt "the enterprise"
g35corona
g35corona
Welcome aboard Steve. It seems like you've been given a laundry list of chores but don't worry. These bikes are highly reliable and the more you ride, the more you'll appreciate them. Let me add to the list...tires tires tires. Even though the tires might look ok with lots of tread, they get hard and dont stick well. Careful riding until you can afford to replace them.
Bob
;BMW;
ex:1986 K100 RT Vin #0091835
2012 R1200 GS
Sage advice from your countrymen Steve. Welcome to the forum and enjoy the bike.
88KE
G'day from Steve, NSW Australia, New member Ir-log1188....May contain nuts!G'day from Steve, NSW Australia, New member Ir-log11
K75RTP - 1994
BIG D
BIG D
Cool
Hi and welcome Steve all the info you will need is on this forum and some great guys as well.
BIG D
