1Back to top Go down   Losing air from front tyre Empty Losing air from front tyre Sat Jan 14, 2012 1:39 pm
MT350Explorer
MT350Explorer
Hi folks,
I'm losing some air from the front tyre. Goes from 2.2 to 1.5 bar overnight. There's no puncture, the valve core has been replaced so it looks like air is escaping from the rim.
My plan is to put the bike on the centre stand and get the front wheel in the air, by jacking beneath the engine with a trolley jack and wooden block and then defalte the front tyre completely. i'm hoping I can then push the tryre back enough from the rim to use a Dremmel to polish the inside of the alloy. This avoids removing the front wheel which looks like a fair bit of extra work.
Anyone tried doing this before? What sort of wheel should I use to polish - is a mild abrasive OK on the three spoke alloys?
Best regards
Dave
2Back to top Go down   Losing air from front tyre Empty Re: Losing air from front tyre Sat Jan 14, 2012 2:53 pm
gee dave its only about 5 bolts ....4 to be loosened and the through bolt to be undone ...might take you all of less than a minute and nickle antisieze is your friend .
just take note of the position of all the spacers etc as you undo the assembly ...it really isnt hard at all
i wouldnt be using any abrasive at all ...maybe some thinners or similar on a cloth to clean up gunk around the bead sealing area .
if you know a good tyre professional .....take it to him for some pointers maybe ?
how old are the tyres ? some times they have a date code on them
3Back to top Go down   Losing air from front tyre Empty Re: Losing air from front tyre Sat Jan 14, 2012 3:45 pm
+1, indeed.
4Back to top Go down   Losing air from front tyre Empty Re: Losing air from front tyre Sat Jan 14, 2012 3:51 pm
robinm
robinm
+2 just take the wheel out, remove the tyre and wire brush the inside of the rim.
5Back to top Go down   Losing air from front tyre Empty Re: Losing air from front tyre Sat Jan 14, 2012 4:09 pm
MT350Explorer
MT350Explorer
Thanks Gents,
I live a long way from any tyre pro's unfortunately!
Sounds simple enough, I've just never tried it.
Dave
1991 K100 RS 16 valve
6Back to top Go down   Losing air from front tyre Empty Re: Losing air from front tyre Sat Jan 14, 2012 5:29 pm
Dave, I've done it a few times and I am no mechanical genius. If you haven't got the workshop manual, go to the download section and find the Clymer manual first, it has easy step by step instructions. You will need a torque wrench to tighten the bolts back up properly.
Good luck mate
Bob
7Back to top Go down   Losing air from front tyre Empty Re: Losing air from front tyre Sat Jan 14, 2012 6:43 pm
Toto_jp
Dave also check the rim for round mine had to be trued had slight oval that you could not see or feel but the tyre kept loosing pressure . Its got a tube in also at the moment Rolling Eyes and I just haven't had the inclination ( read lazy ) to take it out
K100 RS 1986
8Back to top Go down   Losing air from front tyre Empty Re: Losing air from front tyre Sun Jan 15, 2012 6:46 am
BIG D
BIG D
Cool
Dave, as the guy's have suggested it is better with the wheel removed and once cleaned you can see if there is any bad pitting on the rim, even a local National tyre centre do bike tyres and carry the correct sealing compound to seal rim to tyre if its deamed that a sealant is required.
BIG D
9Back to top Go down   Losing air from front tyre Empty Re: Losing air from front tyre Sun Jan 15, 2012 12:05 pm
club_c
club_c
Have you thought about overinflating it slightly and then spraying the tire in stages with a soapy mixture? You should identify the leaking area that way. Or once you've removed the front wheel, dipping it in a tank of water?
1988 K100RS SE VIN 01477554
10Back to top Go down   Losing air from front tyre Empty Re: Losing air from front tyre Sun Jan 15, 2012 5:26 pm
MT350Explorer
MT350Explorer
Thanks for the suggestions Guys, much appreciated. When I find the energy I'll have another look, Clymer manuial in hand. As its showing -6 celsius in the unheated garage, that won't be tonight! Very Happy
Best
Dave
11Back to top Go down   Losing air from front tyre Empty Re: Losing air from front tyre Sat Jan 21, 2012 12:30 pm
MT350Explorer
MT350Explorer
To close this one out; I overinfalted the tyre on the bike (but within the max pressure limit of the tyre), left it for 10 mins, pushed the bike backwards and forwards a few times in the garage and then let some air out to normal pressure and hey presto - it holds pressure Very Happy .
Best regards
Dave
12Back to top Go down   Losing air from front tyre Empty Re: Losing air from front tyre Sat Jan 21, 2012 4:25 pm
good result dave ......i would have used club c' s suggestion with a little soapy water round the bead , to wet up the sealing surfaces ...then dry out with a good seal ...a top suggestion
13Back to top Go down   Losing air from front tyre Empty Re: Losing air from front tyre Sat Jan 21, 2012 4:58 pm
Congratulations with a new avatar Charlie, it looks like Felix is hiding in a dark corner
(maybe because of the strange disease).
14Back to top Go down   Losing air from front tyre Empty Re: Losing air from front tyre Tue Feb 28, 2012 8:57 am
MT350Explorer
MT350Explorer
Ok had em in the bath after finding it's leaking again and it needs a new valve body.
Best
Dave
15Back to top Go down   Losing air from front tyre Empty Re: Losing air from front tyre Tue Feb 28, 2012 3:51 pm
great find dave ....
16Back to top Go down   Losing air from front tyre Empty Re: Losing air from front tyre Tue Feb 28, 2012 4:13 pm
Losing air from front tyre 44271 I hope you took the wheel off before putting it in the bath !! Losing air from front tyre 44271
17Back to top Go down   Losing air from front tyre Empty Re: Losing air from front tyre Tue Feb 28, 2012 4:18 pm
MT350Explorer
MT350Explorer
Cheers Guys!
I tell you one thing I am a past master at making simple jobs complicated Very Happy
Next time I'll drive it through a river crossing wearing an aqualung.
18Back to top Go down   Losing air from front tyre Empty Re: Losing air from front tyre Tue Feb 28, 2012 5:34 pm
col
col
so its ok to bath with your bike but what about sleeping with it
1991 k100lt "the enterprise"
19Back to top Go down   Losing air from front tyre Empty Re: Losing air from front tyre Tue Feb 28, 2012 5:40 pm
too funny Losing air from front tyre 44271
only whilst camping on long trips col ....giggles
