1 Spectacular Tue Jan 24, 2012 8:45 am
komandoalicante
Spectacular is the result of changing lamps a box you buy from DealExtreme
This is the control panel before you start
These lamps, the original with the new cap and without the
With the cap removed or carries lamps
And with the lamps in the new portal
These are the four lighting
And these the clock and the check
And the end result
What do you think?
Warning
Alternator light can not be changed
And the end result
What do you think?
Warning
